Re: 2016 Challenger 5.7 engine noise
[Re: cudascooter]
#2127480
08/07/16 10:52 PM
08/07/16 10:52 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Automatic car? My 16 Ram does same thing.
Mopar to the bone!!!
[Re: cudascooter]
#2128122
08/08/16 07:58 PM
08/08/16 07:58 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Just my opinion, but I think it is because the lifter sits horizontal and allows the oil to drain out. Would love to hear from someone with an Accusump on their engine to see if pressurizing the system before starting made this go away. I've worked on them since they were first introduced, and they all have a slight tick. Also have customers with well over 400K on them with no issues, but still the start up tick. I have seen first hand (or actually heard) that anything but a Mopar filter increases the severity and length of time to pump up the lifters.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: cudascooter]
#2128186
08/08/16 09:23 PM
08/08/16 09:23 PM
72Swinger
Nebraska
My 6.1 in the Dart DOES NOT tick at start up. Always have used Wix 51515R filter which has anti drainback. After running it hard you can hear all the lifters at cruise a little.
[Re: cudascooter]
#2128505
08/09/16 09:06 AM
08/09/16 09:06 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
2012 stick car, quiet as the grave on start up. 41k
Just lucky I guess
"I think its got a hemi"
[Re: cudascooter]
#2129500
08/10/16 02:36 PM
08/10/16 02:36 PM
72Swinger
Nebraska
That filter will not fit your car fyi. Look on their website for one that does that has anti drainback.
[Re: 72Swinger]
#2129566
08/10/16 03:43 PM
08/10/16 03:43 PM
Posts: 372 RI
cudascooter
RI
[Re: wheelsup68dart]
#2142232
08/28/16 12:56 AM
08/28/16 12:56 AM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
have a brand new shaker also , it makes noise , some times i think its worse than other times . IF it BLOWS UP !!!!!! I will put a bigger engine in . my car has 3800 miles on it . I owned mine a hour , and put 69 r/t badges on it .
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
[Re: cudascooter]
#2142828
08/28/16 11:51 PM
08/28/16 11:51 PM
72Swinger
Nebraska
They do have broken exhaust manifold bolt problems thanks to the heat shields.
