Re: Tubing benders
[Re: sgcuda]
#2127947
08/08/16 03:35 PM
08/08/16 03:35 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
For the money, the JD2 is hard to beat. We used one for years and it's very repeatable. DO pay the extra for hydraulics. The hand bender will kill you. Want to step up to a really "nice" top of the line bender, look into a "Tube Shark". This is a really good bender for repeatable if you are building multiples of anything. Probably too costly for one time car bender, but it is a really nice one. Love mine............BUT a JD2 is a grand or so with one set of dies and a Tube Shark is 3K. If you go JD2, opt for the 180 dies
Re: Tubing benders
[Re: Monte_Smith]
#2127953
08/08/16 03:44 PM
08/08/16 03:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
For the money, the JD2 is hard to beat. We used one for years and it's very repeatable. DO pay the extra for hydraulics. The hand bender will kill you. Want to step up to a really "nice" top of the line bender, look into a "Tube Shark". This is a really good bender for repeatable if you are building multiples of anything. Probably too costly for one time car bender, but it is a really nice one. Love mine............BUT a JD2 is a grand or so with one set of dies and a Tube Shark is 3K. If you go JD2, opt for the 180 dies I bent my first moly chassis without the hyd unit... took me about 1 hour per bend... damn near killed me using that ratchet type set up.. but lucky it was a altered for my brother.... made him come over and help pull on the arm... as soon as we got done with one side I ordered the air over hyd unit ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Tubing benders
[Re: sgcuda]
#2127999
08/08/16 04:56 PM
08/08/16 04:56 PM
Posts: 11,721 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
One other big advantage to putting hydraulics on it. Our machine is mounted on a portable stand with wheels. The base is wide and the heavy motor and tank are mounted low. The thing is dead stable, even with a long piece hanging from it. Not using it? Roll it out of the way instead of having it bolted down in the way. Depending on what you are doing, you need plenty of clear space around the machine. Being moveable is a big advantage. Plus, we can pull a 90 in 1.675x.083 4130 in about 20 seconds if you're in a hurry.
Re: Tubing benders
[Re: MR_P_BODY]
#2128134
08/08/16 08:11 PM
08/08/16 08:11 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I had the JD model 104(they dont make it anymore) with the air over hyd... if you plan on bending moly get the hyd unit... with out it you will kill yourself trying to bend moly..... I built a lot of stuff with it.. all my dies were 120*... sold the whole thing about a year ago (after I got done with the Rampage) Yes you did and thank you! Matt
Re: Tubing benders
[Re: sgcuda]
#2128184
08/08/16 09:17 PM
08/08/16 09:17 PM
Quicktree
stay away from the cheap crap, Pro tools makes an American made high quality piece. Can add hydraulic if you want http://shop.pro-tools.com/products/manual-tube-and-pipe-bender-105-heavy-duty-package I bought one a few years back and have barely used it. I have like 5 short radius 180* dies. I think from 1" up most have never been used plus a heavy duty tubing notcher. even have a chassis jig. PM me if you are interested, I'll make you a deal.
Re: Tubing benders
[Re: sgcuda]
#2128301
08/08/16 11:31 PM
08/08/16 11:31 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Just saw a video on the hydraulic setup. Man, that's nice. But, for now, I'm going to have to muscle it. Need the exercise, anyway. I'm probably the only person in my neighborhood that doesn't have a riding lawn mower. If for some strange reason, word gets out and everyone with a Stang or Camaro shows up at my door for a rollbar, I'll bite the bullet at that time. I'm looking forward to custom building my own cage, though. This has become a very cool project for me. Thanks, everyone.
[image][/image]
Re: Tubing benders
[Re: MattW]
#2128304
08/08/16 11:35 PM
08/08/16 11:35 PM
MR_P_BODY
I had the JD model 104(they dont make it anymore) with the air over hyd... if you plan on bending moly get the hyd unit... with out it you will kill yourself trying to bend moly..... I built a lot of stuff with it.. all my dies were 120*... sold the whole thing about a year ago (after I got done with the Rampage) Yes you did and thank you! Matt Was it you I sold it to?.... built anything yet ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Tubing benders
[Re: sgcuda]
#2128312
08/08/16 11:42 PM
08/08/16 11:42 PM
MR_P_BODY
Just saw a video on the hydraulic setup. Man, that's nice. But, for now, I'm going to have to muscle it. Need the exercise, anyway. I'm probably the only person in my neighborhood that doesn't have a riding lawn mower. If for some strange reason, word gets out and everyone with a Stang or Camaro shows up at my door for a rollbar, I'll bite the bullet at that time. I'm looking forward to custom building my own cage, though. This has become a very cool project for me. Thanks, everyone. A couple other things you will need is a nice tubing notcher and I like a oscillating pedistal drum sander to tweak in your cuts... those things make life easier and dont buy cheap hole saws... on moly it just tears the teeth off in one cut... JD also has notchers .... when it comes to welding any joint.... sand both parts first.. even before you tack them
Re: Tubing benders
[Re: JERICOGTX]
#2128315
08/08/16 11:46 PM
08/08/16 11:46 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
What is that called Mike? I NEED one. What I have done has worked, but that is a must have.
Jeff http://www.trick-tools.com/Tube_Pipe_Bending_125 Got all the toys to go with Tube bending
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Tubing benders
[Re: sgcuda]
#2128335
08/09/16 12:00 AM
08/09/16 12:00 AM
sgcuda
Way ahead of you, Mr P. First I wash and rinse the tubing, then I sand both components. Makes for a nice clean weld. Figured that out on the cross braces for the frame.
[image][/image]
Re: Tubing benders
[Re: sgcuda]
#2128439
08/09/16 02:24 AM
08/09/16 02:24 AM
Monte_Smith
North Alabama
Just saw a video on the hydraulic setup. Man, that's nice. But, for now, I'm going to have to muscle it. Need the exercise, anyway. I'm probably the only person in my neighborhood that doesn't have a riding lawn mower. If for some strange reason, word gets out and everyone with a Stang or Camaro shows up at my door for a rollbar, I'll bite the bullet at that time. I'm looking forward to custom building my own cage, though. This has become a very cool project for me. Thanks, everyone. You will wish you had the hydraulic after ONE bend
Re: Tubing benders
[Re: W.I.N. Racing]
#2128522
08/09/16 09:52 AM
08/09/16 09:52 AM
Posts: 10,049 MN
JERICOGTX
MN
Thank you! Looks like a fair price also.
69 GTX
68 Road Runner
Re: Tubing benders
[Re: sgcuda]
#2128525
08/09/16 09:55 AM
08/09/16 09:55 AM
Posts: 10,049 MN
JERICOGTX
MN
Yeah. You're probably right. It will give me something else to strive for. I've done 3 cages with my bender, all by hand. It's not THAT bad. A workout? Yes. End of the world? No. Now if you were say bending .120 wall CM, THAT is a pain... But it's not needed.
69 GTX
68 Road Runner
Re: Tubing benders
[Re: JERICOGTX]
#2128559
08/09/16 11:33 AM
08/09/16 11:33 AM
Posts: 8,351 fredericksburg,va
cudaman1969
fredericksburg,va
Yeah. You're probably right. It will give me something else to strive for. I've done 3 cages with my bender, all by hand. It's not THAT bad. A workout? Yes. End of the world? No. Now if you were say bending .120 wall CM, THAT is a pain... But it's not needed. Agree, and for my entire cage I had 10 bends, not a one at 90, 4 maybe 15 degrees, everything else was straight pipe. FC cage would have a few more, but there is a lot of time between bending,fitting and tacking the pipe so you can "rest up". Its not like you're standing there bending all day long.
Re: Tubing benders
[Re: cudaman1969]
#2128566
08/09/16 11:42 AM
08/09/16 11:42 AM
MR_P_BODY
Yeah. You're probably right. It will give me something else to strive for. I've done 3 cages with my bender, all by hand. It's not THAT bad. A workout? Yes. End of the world? No. Now if you were say bending .120 wall CM, THAT is a pain... But it's not needed. Agree, and for my entire cage I had 10 bends, not a one at 90, 4 maybe 15 degrees, everything else was straight pipe. FC cage would have a few more, but there is a lot of time between bending,fitting and tacking the pipe so you can "rest up". Its not like you're standing there bending all day long. What did you do for the main hoop.. those are usually in the 90* range EDIT As said already... if you arm strong it.. you have to mount the bender... with hyd it can be on wheels since the load is all applied in the bender
Re: Tubing benders
[Re: MR_P_BODY]
#2128577
08/09/16 11:55 AM
08/09/16 11:55 AM
MattW
Ontario Canada
I had the JD model 104(they dont make it anymore) with the air over hyd... if you plan on bending moly get the hyd unit... with out it you will kill yourself trying to bend moly..... I built a lot of stuff with it.. all my dies were 120*... sold the whole thing about a year ago (after I got done with the Rampage) Yes you did and thank you! Matt Was it you I sold it to?.... built anything yet Nope collecting dust will all the other stuff in the garage. Being a busy year. I'll be dead before I get anything automotive done!!! Matt
