Need Help - How do you remove a pilot bearing? #2128222
08/08/16 10:11 PM
08/08/16 10:11 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I can't seem to figure out how to remove this. I can destroy it, but thats not what I want to do lol.. I am thinking something like a pulley remover but I think the hole is too small. Is there a tool specifically out there for this?
Thanks!
RS23L7 4-Speed
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2128224
08/08/16 10:15 PM
08/08/16 10:15 PM
68gtx Offline
68gtx  Offline
There is a puller for the pilot bearing. I would replace if you pull it out.
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2128231
08/08/16 10:22 PM
08/08/16 10:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have not tried it on a bearing, but for a bushing, this worked for me.
Do you have a metal clutch alignment tool?
If so;
Fill the cavity about 5/8 or more full with wheel bearing grease.
Insert tool.
Tap on the clutch alignment tool with a hammer, a brass hammer is advisable.
Add more grease as needed & repeat.
The hydraulic pressure will start the bushing to move out.
Been a long time, but it always worked for me.
Re: Need Help - How do you remove a pilot bearing? [Re: Alaskan_TA] #2128235
08/08/16 10:25 PM
08/08/16 10:25 PM
Danville, NH
Danville, NH
Really.. now that is interesting.. Thanks.
If so;
Insert tool.
RS23L7 4-Speed
Re: Need Help - How do you remove a pilot bearing? [Re: 68gtx] #2128241
08/08/16 10:29 PM
08/08/16 10:29 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
iagree
The one I have is not kind to the bearing. A small slide hammer with a hook on it works also.
And as Barry said, the grease and input shaft works very well with the bushing. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2128244
08/08/16 10:33 PM
08/08/16 10:33 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
You will need a piece of steel round stock that fits tightly in the hole, long enough you can hold it with your hand. Pack the hole with bread. That's correct lunch bread, wheat white it don't mater. I think I even used a hot dog bun once. Now put the round stock in the hole and use a hammer on the exposed end of the steel round bar and hit it hard. You should see some movement of the bearing. Pack some more bread in the hole and repeat.
To install the new bearing or bushing: Clean the hole. Put the bearing in the freezer over night. This will shrink it enough to allow it to quickly slip into place.
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2128274
08/08/16 11:08 PM
08/08/16 11:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Grease or bread(cleaner) works fine.
Here are some 2 and 3 finger internal and external pullers that would probably work.
But they are not the best way, I have a blind hole pullers that is made for specific range of bushings that goes on that big slide hammer. It is 2 pieces and you slide it into the blind hole and screw it together and it expands and a lip locks into behind the bushing and then you use a slide hammer.
Not sure if I have a picture of it? I will keep looking.
Mean while I would use grease or bread if I was you.
Re: Need Help - How do you remove a pilot bearing? [Re: Challenger 1] #2128309
08/08/16 11:39 PM
08/08/16 11:39 PM
Danville, NH
Danville, NH
I think I will try the bread theory, but I must say, until I see it work I am a doubter.. lol.. Thanks guys, I'll let you know.
RS23L7 4-Speed
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2128338
08/09/16 12:02 AM
08/09/16 12:02 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Remember that there are two different bushings depending if they are for a 4 speed crank or an automatic crank.
Re: Need Help - How do you remove a pilot bearing? [Re: Morty426] #2128348
08/09/16 12:08 AM
08/09/16 12:08 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2128379
08/09/16 12:40 AM
08/09/16 12:40 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Wetted down toilet paper works too......grab some sheets off wall, then wet it in the sink now, not toilet water....
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2128394
08/09/16 12:59 AM
08/09/16 12:59 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I know you said you didn't want to destroy it, but that part is easy to find at any part store. 53009180AB is the part number, just in case things don't work out.
Re: Need Help - How do you remove a pilot bearing? [Re: 68KillerBee] #2128404
08/09/16 01:10 AM
08/09/16 01:10 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
One of these.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2128589
08/09/16 12:07 PM
08/09/16 12:07 PM
crlush Offline
crlush  Offline
I have done the grease packed half way and find some round stock close to fitting tight if it's close you can wrap some masking tape around it till it fits snug then just hit it with a good size hammer
Re: Need Help - How do you remove a pilot bearing? [Re: Alaskan_TA] #2128661
08/09/16 01:35 PM
08/09/16 01:35 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
If so;
Insert tool.
This was the standard way to remove pilot bushings for the last 100 years.... Works really well...
As an ad here, IF you use a pilot BUSHING, NEVER lube it with anything... Bushings are self lubricating and lubing them can cause clutch chatter.... Been there done that.....
Re: Need Help - How do you remove a pilot bearing? [Re: Alaskan_TA] #2128686
08/09/16 01:59 PM
08/09/16 01:59 PM
pa.
dan9 Offline
dan9  Offline
pa.
That method always worked for me too. A piece of wooden dowel rod from the hardware store in the proper size will work if you don't have an extra input shaft.
Re: Need Help - How do you remove a pilot bearing? [Re: Alaskan_TA] #2128696
08/09/16 02:07 PM
08/09/16 02:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
If so;
Insert tool.
iagreeMe too hammer
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2128776
08/09/16 04:10 PM
08/09/16 04:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The OP's setup appears to be an adapter bearing, not bushing. The grease, bread, toilet paper packing might just ooze past the individual rollers when smacked. The internal-jaw puller Jim posted works every time. Harbor Freight has them.
Re: Need Help - How do you remove a pilot bearing? [Re: John_Kunkel] #2129013
08/09/16 10:37 PM
08/09/16 10:37 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I use this tool. Works great. It is a Snap-on, I've had it for decades. Probably costs a million dollars now...
Re: Need Help - How do you remove a pilot bearing? [Re: John_Kunkel] #2129067
08/09/16 11:14 PM
08/09/16 11:14 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Good point....
I saw it was a bearing but thought this method might still work without purchasing a puller..
