Need Help - How do you remove a pilot bearing?
#2128222
08/08/16 10:11 PM
08/08/16 10:11 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I can't seem to figure out how to remove this. I can destroy it, but thats not what I want to do lol.. I am thinking something like a pulley remover but I think the hole is too small. Is there a tool specifically out there for this?
Thanks!
RS23L7 4-Speed
Re: Need Help - How do you remove a pilot bearing?
[Re: Alaskan_TA]
#2128235
08/08/16 10:25 PM
08/08/16 10:25 PM
Mopar_Mike
Danville, NH
Really.. now that is interesting.. Thanks. I have not tried it on a bearing, but for a bushing, this worked for me.
Do you have a metal clutch alignment tool?
If so;
Fill the cavity about 5/8 or more full with wheel bearing grease.
Insert tool.
Tap on the clutch alignment tool with a hammer, a brass hammer is advisable.
Add more grease as needed & repeat.
The hydraulic pressure will start the bushing to move out.
Been a long time, but it always worked for me.
RS23L7 4-Speed
[Re: 68gtx]
#2128241
08/08/16 10:29 PM
08/08/16 10:29 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
There is a puller for the pilot bearing. I would replace if you pull it out. The one I have is not kind to the bearing. A small slide hammer with a hook on it works also. And as Barry said, the grease and input shaft works very well with the bushing. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
[Re: Mopar_Mike]
#2128274
08/08/16 11:08 PM
08/08/16 11:08 PM
Challenger 1
Cincinnati, Ohio
Grease or bread(cleaner) works fine. Here are some 2 and 3 finger internal and external pullers that would probably work. But they are not the best way, I have a blind hole pullers that is made for specific range of bushings that goes on that big slide hammer. It is 2 pieces and you slide it into the blind hole and screw it together and it expands and a lip locks into behind the bushing and then you use a slide hammer. Not sure if I have a picture of it? I will keep looking. Mean while I would use grease or bread if I was you.
[Re: Challenger 1]
#2128309
08/08/16 11:39 PM
08/08/16 11:39 PM
Mopar_Mike
Danville, NH
I think I will try the bread theory, but I must say, until I see it work I am a doubter.. lol.. Thanks guys, I'll let you know.
RS23L7 4-Speed
[Re: Alaskan_TA]
#2128661
08/09/16 01:35 PM
08/09/16 01:35 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
If so;
Insert tool.
Been a long time, but it always worked for me. This was the standard way to remove pilot bushings for the last 100 years.... Works really well... As an ad here, IF you use a pilot BUSHING, NEVER lube it with anything... Bushings are self lubricating and lubing them can cause clutch chatter.... Been there done that.....
[Re: Mopar_Mike]
#2128776
08/09/16 04:10 PM
08/09/16 04:10 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The OP's setup appears to be an adapter bearing, not bushing. The grease, bread, toilet paper packing might just ooze past the individual rollers when smacked. The internal-jaw puller Jim posted works every time. Harbor Freight has them.
[Re: John_Kunkel]
#2129067
08/09/16 11:14 PM
08/09/16 11:14 PM
minivan
Eugene, Oregon
Good point.... I saw it was a bearing but thought this method might still work without purchasing a puller..
