Disc brake caliper change in 71 question #2128112
08/08/16 07:42 PM
08/08/16 07:42 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
About what time frame in 1971 did they change from the wide mouth caliper to the small?
TIA
Re: Disc brake caliper change in 71 question [Re: 5carguy] #2128324
08/08/16 11:55 PM
08/08/16 11:55 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Any chance you can post a pic of the difference so I know what I am looking for?
Most of the changes in 71 I believe happened in May/June
Re: Disc brake caliper change in 71 question [Re: 5carguy] #2128376
08/09/16 12:38 AM
08/09/16 12:38 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
TIA
There is no way of knowing an answer to that question.
Probably the first few weeks of production, would be my thoughts.
Till the supply in inventory from Kelsey Hayes was used up, on the assembly line.
Some pictures of the wide mouth calipers that i sold off from my collection, stash, hoard, of parts.
3505S Carter & 1970 Caliper 016 (Copy).JPG3505S Carter & 1970 Caliper 017 (Copy).JPG
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Disc brake caliper change in 71 question [Re: hemi71x] #2128532
08/09/16 10:31 AM
08/09/16 10:31 AM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Chris,
A quick way to tell the difference in the 70 vs the 71 style (other than the width of the front support pads) is the number of circles cast into the back side. The 70 style has 2 circles, and the 71 style only has 1 circle. The reference pic below is the 70 style. I searched and don’t have a 71 reference pic available.
Rob
Re: Disc brake caliper change in 71 question [Re: 5carguy] #2128571
08/09/16 11:51 AM
08/09/16 11:51 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Here's some pictures of the later style.
Re: Disc brake caliper change in 71 question [Re: 5carguy] #2128747
08/09/16 03:32 PM
08/09/16 03:32 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Is there an advantage to either one?
NS1AAR
Re: Disc brake caliper change in 71 question [Re: ns1aar] #2128751
08/09/16 03:39 PM
08/09/16 03:39 PM
hemi71x Offline
hemi71x  Offline
Nope.
Re: Disc brake caliper change in 71 question [Re: 5carguy] #2128788
08/09/16 04:35 PM
08/09/16 04:35 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Only if you are doing an OE correct car and you know based on year (or SPD) that your car had one style or the other.
Re: Disc brake caliper change in 71 question [Re: 5carguy] #2128880
08/09/16 07:32 PM
08/09/16 07:32 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I think my original question should have been these later style calpers were on my SPD Feb 71 Cuda.Are they correct or have they been changed?
Re: Disc brake caliper change in 71 question [Re: 5carguy] #2128897
08/09/16 08:00 PM
08/09/16 08:00 PM
hemi71x Offline
hemi71x  Offline
What are you trying to say here?
You currently have the "wide mouth" calipers on your vehicle, and want to know if they have been replaced onto the car, in it's lifetime, or you have the "standard" opening caliper on the car.
Ya, you got me confused.
In a February build date, i would feel certain that the regular, standard, opening caliper would have been installed on the assembly line.
But what's the big deal anyway?
There is no way of ever knowing.
I ordered a Cuda in May 71, built at the end of June, Delivered in July, and it had the standard opening calipers on it.
How do i know this, you ask?
Because i kept the car for 38 years before i sold it off, and believe me, i took, repaired, that vehicle a lot in the 300,000 + miles that i put on it.
Re: Disc brake caliper change in 71 question [Re: 5carguy] #2129008
08/09/16 10:35 PM
08/09/16 10:35 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have a set that are off a SPD 630 car and they are single dot small mouth type
Re: Disc brake caliper change in 71 question [Re: Morty426] #2129330
08/10/16 11:37 AM
08/10/16 11:37 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I thank you for that information.
Re: Disc brake caliper change in 71 question [Re: 5carguy] #2134751
08/16/16 10:30 PM
08/16/16 10:30 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Learn something new every day.
