Carbon Fibre Hood? #2127793
08/08/16 12:39 PM
08/08/16 12:39 PM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
Just wondering if anyone here has got a carbon fibre hood on there ride?
If you do who did you get it from?
I'm in the market for a carbon fibre hood for my 70 Plymouth GTX
Thanks for any and all info
Kevin
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2127812
08/08/16 01:12 PM
08/08/16 01:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have one on my P-Body.... but I made it... no one
makes anything for my ride
wave
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2127840
08/08/16 01:57 PM
08/08/16 01:57 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Almost in every case, any typical fiberglass existing hood mold will also be fine for a carbon hood/part. The issue is, if one can find an existing mold, although making one is only a matter of time/effort/money. You need to ask, costs per part are not that much greater, more supply/demand pricing. They are anaziningly pretty stiff.
I'm in the early stages of doing a CF replacement/redesign radiator support on one of my cars, we'll see. grin twocents
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2127894
08/08/16 02:31 PM
08/08/16 02:31 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You have to be careful when you order carbon parts. The material costs twice as much, but weighs the same as fiberglass. The ONLY way the carbon hood is lighter, is because there is less of it, because of strength. BUT and here is the tricky part........to lay up the super light weight, super thin carbon stuff, you have to be able to pull a vacuum on the mold to do it correctly and few can do that. Also the "carbon" parts you get from some companies not only weigh the same as glass, they are also not really carbon. They will be glass, with the final layer carbon, to give it the "look".
So if you are looking for a true, super light carbon hood for a 70 GTX, probably not going to find such a thing. If you just want the "look" buy a glass one and have a carbon wrap put on it
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2127900
08/08/16 02:35 PM
08/08/16 02:35 PM
ONTARIO,CANADA
ONTARIO,CANADA
Ok so I'm probably better off sticking with Fiberglass then.
Who do you guys recommend for a quality glass hood?
Kevin
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2127903
08/08/16 02:41 PM
08/08/16 02:41 PM
fullmetaljacket Offline
Dip it and take off an honest 15 or so pounds and keep the steel look while you're at it.
There's a guy in Detroit that is an ace on the stuff.
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2127943
08/08/16 03:23 PM
08/08/16 03:23 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Kevin
Glasstek is probably your best choice
Re: Carbon Fibre Hood? [Re: Monte_Smith] #2127948
08/08/16 03:36 PM
08/08/16 03:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When you do the vac on CF there is other stuff that
has to be applied so when its vac down it sucks up all
the extra reson ... I had to build a big bag to vac it
but I screwed up and didnt have my stiffeners on it when
I vac it down so I added them after but didnt vac them...
I could have gone with 2 layers of CF but I put 3 layers
on it.. if done right 2 is plenty... my hood weighs 6#..
my fiberglass one was 17# but that was with the scoop
wave
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2127955
08/08/16 03:47 PM
08/08/16 03:47 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
To give an idea of what NICE carbon fiber weighs. Customer with a Pro-Mod 63 Vette. The nose on those is pretty big. His entire nose and hood, with a 6" cowl and a titanium tree, weighed 11 pounds. Entire carbon bodies from 5 star bodies can weigh as little as 40 pounds
Re: Carbon Fibre Hood? [Re: Monte_Smith] #2127971
08/08/16 04:09 PM
08/08/16 04:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I was listening to yesterdays BS when they were
in the rain delay.. and they said about 60# for a funny
car body... I still thought that was light... I've always
noticed that they always have the big guy open the body
after the burn out... but I think thats for height
wave
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2127986
08/08/16 04:36 PM
08/08/16 04:36 PM
mack Offline
mack  Offline
My DP Challenger came with a CF hood... About two years ago the scoop came off and it wasn't the hood or the scoop it was the lament that was used to attach.. Anyway, I remember the hood being as heavy as the scoop. I didn't weigh either but they felt the same.. That was close enough for me.. I do know that Mike Pustalny (SP) has CF and Glass hoods for the DP's that want to put them on springs and a hood latch like a normal car and get rid of the 12 fasteners.. He might have an outlet for other CF hoods... Might be worth a call... All he can say is no...
Mack Reeves SST 2377 FS/D 2377
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2128015
08/08/16 05:35 PM
08/08/16 05:35 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Kevin
I for the life of me can't see how that conclusion could be drawn from the prior replies to you making it.
The material costs are indeed higher, the CF, which has already been mentioned, but you need a lot less thickness with CF for equal stiffness, and the extra epoxy cost. There is no gel coat normally with CF. However the actual material costs are only a fraction of the total delivered price, and CF is way worth it weight wise, and does a better jib of retaining its shape in use, then FG/resins. Vacuum bagging any composite part is always preferred, but seldom done with FG. I would not toss the towel in so fast.
Re: Carbon Fibre Hood? [Re: fullmetaljacket] #2128033
08/08/16 05:58 PM
08/08/16 05:58 PM
ONTARIO,CANADA
ONTARIO,CANADA
I've got the whole front clip acid dipped and I need the clearance for the intake
Kevin
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2128035
08/08/16 06:03 PM
08/08/16 06:03 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
About anyone who lays up glass hoods, can and will do carbon......however, as I mentioned earlier, if they are not doing it right, you lose little to no weight and pay twice as much. And the companies who generally do the really nice, light weight race carbon are likely not to have a hood mold for a 70 Plymouth
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2128057
08/08/16 06:30 PM
08/08/16 06:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One thing you will see in fiberglass is that it moves
in heat(sun light).. this doesnt happen with CF.. I
made my first hood in fiberglass.. it would sag in the
sunlight after a few hours... that was the reason I changed
over to CF... the hood I have on my Rampage is from AAR in
Florida.. nice piece... BUT it still moves in the heat.. I
might take a mold off of it and build it in CF.. I'll see within
a year.. if it continues to move like it has been I will pull
a mold if I can get it back to the proper shape
EDIT
You would be far better off going with CF... if you can
find a shop that has the mold for your hood and your willing
to pay the price.... way lighter, way stronger, doesnt move
in the heat.... make some calls.... a few questions will
tell you if its all cf or over fg... cf has a weight and
the reson after vac is almost nothing... just ask the weight
of the cloth they will use and if they will vac it down...
they dont vac fg
wave
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2128064
08/08/16 06:40 PM
08/08/16 06:40 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i modified my Kevlar front clip with carbon when i changed the front edge but this is a one off.
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2128095
08/08/16 07:18 PM
08/08/16 07:18 PM
ONTARIO,CANADA
ONTARIO,CANADA
I'm not saying I don't want cf but if it's going to be 3 or 4 the price of fg and they can't do the cf procedures properly.
I'm way further ahead buying a fg hood, so besides cloth thickness and if they vac cf parts what else should I ask?
Kevin
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2128217
08/08/16 10:08 PM
08/08/16 10:08 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
If you know someone with a mold, ask if they can do Kevlar. That front clip I posted can be held above my head with just 1 hand. It is so light. If I could tape both my doors n bootlid to it I could still lift it with 1 hand. If you know any boat builders, they could possibly help you.
Re: Carbon Fibre Hood? [Re: 604 Hemi GTX] #2128299
08/08/16 11:30 PM
08/08/16 11:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kevin
Really nothing other than number of layers and support
ribs.. 2 layers is fine if it has good supports and
location of them.... and of course price
wave
Re: Carbon Fibre Hood? [Re: rebel] #2128308
08/08/16 11:38 PM
08/08/16 11:38 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I would only suggest Kelvar if one felt part was going to be abused in use, and separating from the car would be a bad thing after contact. In the case of a hood that could be good or bad. Kevlar is not as strong as CF, just a lot harder to separate after failure, where Cf will mainly shatter when it fails. A single layer of Kevlar with the CF is not a bad compromise, I do it often. twocents
edited
