Re: Front pump leak on 904, tried everything...
[Re: DemonDust]
#2127106
08/07/16 01:32 PM
08/07/16 01:32 PM
RapidRobert
yes I would use some sealer as unfortunately part dimentions ain't perfect. I would use "the right stuff" gasket maker, a thin/even amt. it WILL seal! EDIT some on the bolt threads too
[Re: DemonDust]
#2127112
08/07/16 01:44 PM
08/07/16 01:44 PM
Posts: 11,639 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I use some teflon sealant or even silicone on the bolt threads as they are not blind holes. No other real leak issues there that I can remember. Any damage on the pump bore in the case? Does the front drum have the small hole drilled under the piston for use with a transbrake? If so, oil may be getting out of the vent and running down. I would not object to using a bit of silicone to help seal the o-ring if it was needed. Any silicone in a transmission is applied sparingly.
[Re: DemonDust]
#2127120
08/07/16 01:53 PM
08/07/16 01:53 PM
Thumperdart
State of confusion
Are you SURE it`s not dripping down from the converter hub seal.........
[Re: Thumperdart]
#2127126
08/07/16 02:00 PM
08/07/16 02:00 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Are you SURE it`s not dripping down from the converter hub seal......... Yes, it's dry below the converter snout. It's just the bottom, of the pump that's wet.
[Re: DemonDust]
#2127280
08/07/16 06:21 PM
08/07/16 06:21 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Check the front band lever shaft hole plug.
[Re: DemonDust]
#2127781
08/08/16 12:17 PM
08/08/16 12:17 PM
Posts: 2,158 Hamilton,Ohio
POZEST
Hamilton,Ohio
Try pressure checking the converter while its out. Mine was weeping where it seats into the rear of the crank. I rigged up it with some stuff from lowes to check it. Good luck.
"I'm not a Gynecologist, but I'll take a look."
