Re: Holley jet sizes
[Re: Shatar4]
#2127839
08/08/16 01:57 PM
08/08/16 01:57 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Does the carb have power valves in it? If it does make sure the throttle linkage is adjusted so it is on the idle circuit only and not up on the transition circuit when idling You may need to adjust the idle screws in so it has from 1/8 to 3/4 turn out from bottom with the linkaged on the idle circuits only on all the idle screws The jet sizes should not influence the idle air fuel ratio There are four or five different circuits in both the primary and secondary parts of the carbs. depending on if it has both four corner idle and power valves in both ends of the carb. Good luck. let us know what you find and do, that will help others on here later
[Re: Shatar4]
#2128106
08/08/16 07:30 PM
08/08/16 07:30 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
The engine is a 505 stroker and the carb is a ProSystem 1000 cfm. The jets that are in it are 92 front and back. Way to rich. Add idle timing, leave total timing where it is. It will take more fuel with more timing. I am running 94's in my 1000 on my 512...Also, what idle bleeds are in it and HS bleeds are in it. You should have #70 idle bleeds, and #27-32 HS bleeds...I run the #27-#28's and it is dead on.
[Re: Shatar4]
#2128230
08/08/16 10:21 PM
08/08/16 10:21 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
The engine is a 505 stroker and the carb is a ProSystem 1000 cfm. The jets that are in it are 92 front and back. Way to rich. How do you know the the primary main circuit is way too rich?
[Re: Dragula]
#2128653
08/09/16 01:21 PM
08/09/16 01:21 PM
Posts: 1,038 Howell, Mi
Shatar4
Howell, Mi
The engine is a 505 stroker and the carb is a ProSystem 1000 cfm. The jets that are in it are 92 front and back. Way to rich. Add idle timing, leave total timing where it is. It will take more fuel with more timing. I am running 94's in my 1000 on my 512...Also, what idle bleeds are in it and HS bleeds are in it. You should have #70 idle bleeds, and #27-32 HS bleeds...I run the #27-#28's and it is dead on. Idle bleeds are #76 and the HS bleeds are #32. I'll add more idle timing and see what it does. Thanks for the suggestion!
[Re: Shatar4]
#2131833
08/13/16 11:10 AM
08/13/16 11:10 AM
Dragula
The engine is a 505 stroker and the carb is a ProSystem 1000 cfm. The jets that are in it are 92 front and back. Way to rich. Add idle timing, leave total timing where it is. It will take more fuel with more timing. I am running 94's in my 1000 on my 512...Also, what idle bleeds are in it and HS bleeds are in it. You should have #70 idle bleeds, and #27-32 HS bleeds...I run the #27-#28's and it is dead on. Idle bleeds are #76 and the HS bleeds are #32. I'll add more idle timing and see what it does. Thanks for the suggestion! Change idle bleeds to #70-#71 too...Then start working the HS bleeds down while watching plugs.
