torqflite race fluid level? #2127504
08/07/16 11:13 PM
08/07/16 11:13 PM
gregsdart Offline OP
I have the vent in the top rear of the main case. At 1/2 quart low it still pushes enough fluid out to make a mess. I run a B&M deep cast pan, so there is plenty of fluid capacity. How much are you all running? Anyone running a catch can?
Re: torqflite race fluid level? [Re: gregsdart] #2127519
08/07/16 11:29 PM
08/07/16 11:29 PM
On all of my 727 with deep pans I make sure the fluid level is below the add mark cold and not above the add mark hot twocents
Re: torqflite race fluid level? [Re: gregsdart] #2127521
08/07/16 11:35 PM
08/07/16 11:35 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I use to have the same issue, I ran the vent plastic overflow tank, took care of the problem that way, mine did it worse if I was using the transbrake. Didn't ever leak much, but always drips under the car until I did that.
Re: torqflite race fluid level? [Re: gregsdart] #2127531
08/07/16 11:40 PM
08/07/16 11:40 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Did u plug the govnor feed hole in the park gear? My 904 used to push about 2 shot glasses of oil in the catch can. Plugged the feed hole, now i only get a drop or two after a weekend of hammering.
Re: torqflite race fluid level? [Re: gregsdart] #2127535
08/07/16 11:44 PM
08/07/16 11:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've seen people put the rear vent on the front side of the rear bulkhead (above the band/drum) that ends up making a mess. Putting it at the very rear of the case, drilled into the cavity under the rear support, I've never had one leak. Even putting it in the extension housing, it picks up oil slung from the output shaft. Not sure where your's is located.
Re: torqflite race fluid level? [Re: gregsdart] #2127552
08/07/16 11:56 PM
08/07/16 11:56 PM
Mine is located at about 11 o'clock on the main case one inch from the tailshaft housing. I will have to check on the guvnor feed hole. I did add a puke can of about 8 oz capacity with a 3/8 hose from the vent tube to the can, but there was still fluid dripping off the whole rear of the trans plus a couple of ounces in the puke can after seven passes. I clamped a screen to the end of the hose to try and separate out the oil, and will run less fluid, will try a quart low or so.
Re: torqflite race fluid level? [Re: gregsdart] #2127571
08/08/16 12:06 AM
08/08/16 12:06 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If you are an inch from the end of the case instead of right at the edge, you may be in main case area. I go so far as to put it top of the case to make certain it's out of oil laying in that area and have never had an issue with leaks. Just have to be careful it doesn't get broken off.
Re: torqflite race fluid level? [Re: gregsdart] #2127586
08/08/16 12:19 AM
08/08/16 12:19 AM
The vent may be closer than I mentioned. I will have to look and see.
Re: torqflite race fluid level? [Re: gregsdart] #2127674
08/08/16 08:15 AM
08/08/16 08:15 AM
tboomer Offline
tboomer  Offline
Great question Greg! Mine pukes a bit too. Need to take a peek under the car! wave
Re: torqflite race fluid level? [Re: tboomer] #2127676
08/08/16 08:20 AM
08/08/16 08:20 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
iagree
I'm building a new trans for the Charger and was about to ask where to put the vent.
Thanks for the pic, CMcAllister. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: torqflite race fluid level? [Re: gregsdart] #2127688
08/08/16 09:32 AM
08/08/16 09:32 AM
We know that launch forces must send the fluid flying to the rear of the case on launch. I always thought that the deep pan was to keep the filter covered so the pump doesn't pull air. But if you think about it a second, low gear has little demand for pump volume, correct? Would that allow for any air drawn in to be cleared out? So the question becomes how deep of a pan is best, or minimum for faster cars, and how much can the level be lowered before trouble.
Cab, I see you run all your TFs 3/4 inch low roughly. Never any problem, I take it?
Re: torqflite race fluid level? [Re: gregsdart] #2127710
08/08/16 10:35 AM
08/08/16 10:35 AM
Finland, Europe
Ck[FIN] Offline
Ck[FIN]  Offline
Finland, Europe
I always had problems with the puke. Pushes out 1-3 ounces after every run when i let go off the throttle. +9000rpm. I have vent relocated exactly like the picture. I just installed a metal can in the firewall where the hose is at the bottom. It pukes there and drains back automatically, no problem ever since.
-1965 Valiant 9.03s 358cu.in R5P7-
Re: torqflite race fluid level? [Re: gregsdart] #2127909
08/08/16 02:47 PM
08/08/16 02:47 PM
No problems yet that I know of shruggy I use the Mopar stamped steel deep pan kits usually upI have one older Pro Trans fully tricked out 727 SS/AH tranny Dave did years ago that has a B&M aluminum deep pan on it, it has a slosh baffle welded onto the back oil pan rail to help keep the oil from slosking back into the tail shaft housing work devil up
Re: torqflite race fluid level? [Re: Cab_Burge] #2127967
08/08/16 04:03 PM
08/08/16 04:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My buddy was moving the vent because it leaked most
of the time when it got hot... I gave him my 727 book
that shows that pick and I told him what to do... he
even put a hose on it running up to the firewall but
no bottle... so far he is fine... only did it hot
wave
Re: torqflite race fluid level? [Re: gregsdart] #2128118
08/08/16 07:53 PM
08/08/16 07:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t even know where my vent is but Pro-Trans went through mine years ago so they obviously have that figured out cos never a drop up front......... work
Re: torqflite race fluid level? [Re: Thumperdart] #2128125
08/08/16 07:59 PM
08/08/16 07:59 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
When using a t-brake u have to plug the vent in the pump & move it to rear or the main case.
