Difference between B and RB distributors? #2127257
08/07/16 05:44 PM
08/07/16 05:44 PM
Andrews,In. U.S.of A.
67_Satellite Offline OP
Don't have one of each in front of me to compare.Is the body the same with a different length shaft , or are they different length bodies?
Re: Difference between B and RB distributors? [Re: 67_Satellite] #2127275
08/07/16 06:16 PM
08/07/16 06:16 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Bodies are exactly the same, only the shaft is different.
Direct Connection used to sell a spacer kit so that you could use a 440 distributor in a 383
Re: Difference between B and RB distributors? [Re: Morty426] #2127276
08/07/16 06:17 PM
08/07/16 06:17 PM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Abe Lincoln
Re: Difference between B and RB distributors? [Re: dart4forte] #2127305
08/07/16 07:01 PM
08/07/16 07:01 PM
Thank you.I eventually found the info on page 699 of the 8 the edition mopar engine 'bible"
Re: Difference between B and RB distributors? [Re: 67_Satellite] #2127306
08/07/16 07:02 PM
08/07/16 07:02 PM
Mesa, Arizona
Mesa, Arizona
There's several other vendors that sell the adapters
Abe Lincoln
Re: Difference between B and RB distributors? [Re: 67_Satellite] #2127465
08/07/16 10:31 PM
08/07/16 10:31 PM
I ain't done it but I wouldn't be afraid to trim down a RB dist to fit & it'd let you get all of the rotational and axial play out of the dist tang/intergear slot interface. first I would shim the lower dist shaft to .005" axial play & be sure to deburr all sharp edges when grinding
