Most powerful alternator on stock wiring
#2126960
08/07/16 05:31 AM
08/07/16 05:31 AM
Posts: 206 Los Angeles CA
xyxxjx
Los Angeles CA
I'm in the process of changing the fuel pump . I'm thinking about changing the alternator too since i have to take it off to get to the fuel pump. What's the most powerful alternator I can run on the stock wire gauges? I'm looking for b4b (bang for the buck) solution.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far.
Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be.
Don't protect a feminist when the collapse comes!
Re: Most powerful alternator on stock wiring
[Re: xyxxjx]
#2127080
08/07/16 12:46 PM
08/07/16 12:46 PM
RapidRobert
I'm thinking about changing the alternator too since i have to take it off to get to the fuel pump. If things are OK now I would suggest leaving it as is & concentrate on the issues that need to be dealt with. If you pull/clean the bulkhead it will take care of most any potential electrical issues & never use the alt to charge a depleted battery (use a regular battery charger). Otherwise as said the 78 amper is the most powerful stock one except for the big 100 amp beast with the fan blades behind the pulley & it has special bracketry & is heavy but is a good piece. the 78 amper has a thin stator so a slight fore/aft mounting adjustment is needed (washers/spacers)
[Re: Andrewh]
#2127123
08/07/16 01:57 PM
08/07/16 01:57 PM
Posts: 4,153 Canada -- Posts: 4034 -Registe...
5thAve
The common misconception is that the alt drives an amount of current. That is not true. you can put a 2000 amp alt on any car and the car will not burn up. it is based on the draw the car needs.
At the same time tho the wiring is usually sized for the stock alternator. If you need a bigger alternator you're going to be pulling more current then the wiring was designed for so you should be using bigger gauge wiring to match. But if someone is just upping the size of their alternator for the hell of it then it doesn't matter.
[Re: BDW]
#2127142
08/07/16 02:28 PM
08/07/16 02:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you do the amp bypass, run a large wire directly from alternator to battery relay, you won't have to worry about the stock wiring carrying the load. Battery relay? You realize that all electrical loads are, by design, supported by the alternator when the engine is running. All your "trick" does is feed the battery direct, everything else still pulls off the stock wiring and now you've severely increased the load on the wiring from the battery to the fuse box. Prior to your "trick" that load came from the alternator output to the fuse box. This is a poorly thought out "cure" for a problem that shouldn't exist.
[Re: xyxxjx]
#2127178
08/07/16 03:38 PM
08/07/16 03:38 PM
Challenger 1
Cincinnati, Ohio
I got 2 cars with these alternators, one since 2005. They are stock cases nothing special on the outside and cost about 150 bucks I think? I really can't remember somewhere around there. Is it worth it? Yea I think so because they charge better at idle. One my cars have stock wiring and AC that is why I wanted a up graded alternator for at night during the summer with the AC running. My lites stay more steady now at idle or low speeds. No trouble out of either alternator so far, one since 2005.
[Re: xyxxjx]
#2127186
08/07/16 03:50 PM
08/07/16 03:50 PM
Posts: 4,740 Florida
BDW
Good catch, it's actually the starter relay. Nice to have someone with plenty of free time to clear up important things. http://www.allpar.com/history/mopar/electrical.htmlStock wiring can handle the stock loads. Any new parts, electrical fuel pumps or fans, should also be run directly off alternator through a relay.
[Re: Challenger 1]
#2127223
08/07/16 04:52 PM
08/07/16 04:52 PM
Posts: 2,592 None
71rm23
None
I got 2 cars with these alternators, one since 2005. They are stock cases nothing special on the outside and cost about 150 bucks I think? I really can't remember somewhere around there. Is it worth it? Yea I think so because they charge better at idle. One my cars have stock wiring and AC that is why I wanted a up graded alternator for at night during the summer with the AC running. My lites stay more steady now at idle or low speeds. No trouble out of either alternator so far, one since 2005. I have the same one, double pulley, challenger1. Just received and waiting for another part to install on my engine. Trying to get all engine stuff on my engine after paint
[Re: 71rm23]
#2127256
08/07/16 05:42 PM
08/07/16 05:42 PM
Challenger 1
Cincinnati, Ohio
I hope your happy with it. I think you will be. Good luck on your motor build. My motor in 05 and it is still in the car just like this. I haven't taken anything off of it since I don't think? except I went with stock painted valve covers before it went into the car. Some spare parts I threw together into this 318 challenger. Donut cutter before Woodward last summer 2015.
[Re: xyxxjx]
#2127572
08/08/16 12:06 AM
08/08/16 12:06 AM
xyxxjx
Los Angeles CA
I wasn't able to find this 78 amp alternator. Anyone have a link to one?
[Re: RapidRobert]
#2127579
08/08/16 12:13 AM
08/08/16 12:13 AM
xyxxjx
Los Angeles CA
I'm thinking about changing the alternator too since i have to take it off to get to the fuel pump. If things are OK now I would suggest leaving it as is & concentrate on the issues that need to be dealt with. If you pull/clean the bulkhead it will take care of most any potential electrical issues & never use the alt to charge a depleted battery (use a regular battery charger). Otherwise as said the 78 amper is the most powerful stock one except for the big 100 amp beast with the fan blades behind the pulley & it has special bracketry & is heavy but is a good piece. the 78 amper has a thin stator so a slight fore/aft mounting adjustment is needed (washers/spacers) This is am excerpt from the link someone posted earlier. "If your original alternator was 35 amps or less, we also recommend that you change the ammeter wiring to a thicker gauge. This will allow the charging system to use the extra amps more efficiently without having to worry about overheating or melting your existing ammeter wiring harness." But you guys are saying if I put the 78 amp alt in I won't have to worry about melting wires, right?
[Re: xyxxjx]
#2127595
08/08/16 12:25 AM
08/08/16 12:25 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I run the chrome unit like Challangers.Been in th 65 since 2000.No problems ever but I dont have much draw.My kid uped the alt in the 62 300 when he had it went from 35 to 65.ran it for almost 15 years.no problems and he ran a big stereo and hi output headlight but they were halogens like in my 65.Alt wont usually creat a problem unless you have lots of after market add ons.I do bypass the amp meter as they were bad even new.A larger alt and replacing the points reg with the solid state makes idle lighting better.Rocky
Chrysler Firepower
[Re: xyxxjx]
#2127613
08/08/16 01:14 AM
08/08/16 01:14 AM
RapidRobert
But you guys are saying if I put the 78 amp alt in I won't have to worry about melting wires, right? correct. clean the bulkhead male/female brass terminals well especially the 2 main in/out circuits (4 brass terminals)/clean large batt cables including ground path (batt to block/block to firewall) and keep the ammeter needle close to 12 O'clock.
[Re: RapidRobert]
#2127631
08/08/16 01:58 AM
08/08/16 01:58 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
But you guys are saying if I put the 78 amp alt in I won't have to worry about melting wires, right? correct. clean the bulkhead male/female brass terminals well especially the 2 main in/out circuits (4 brass terminals)/clean large batt cables including ground path (batt to block/block to firewall) and keep the ammeter needle close to 12 O'clock. Mopar electronics, what me worry?
[Re: Challenger 1]
#2127663
08/08/16 05:46 AM
08/08/16 05:46 AM
Posts: 2,592 None
71rm23
None
I hope your happy with it. I think you will be. Good luck on your motor build. My motor in 05 and it is still in the car just like this. I haven't taken anything off of it since I don't think? except I went with stock painted valve covers before it went into the car. Some spare parts I threw together into this 318 challenger. Donut cutter before Woodward last summer 2015. Me too, Challenger1. I think I know where the bracketry and everything else came from on your car. It sure looks good! I have everything as you do on your car. I just have to get working on it when I get back home. Oh, the list is looong for things to do
