Can't get belts off alternator #2126928
08/07/16 02:27 AM
08/07/16 02:27 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I've removed bolt 1 and loosened bolt 3 in the attached picture. I pushed the alternator towards the engine but it doesn't go far enough to get the belts off. How do I get those belts off?
https://drive.google.com/file/d/0B8IgeG75F_MIc0UtWmxsX1ppUFk/view?usp=drivesdk
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
Re: Can't get belts off alternator [Re: xyxxjx] #2126933
08/07/16 02:44 AM
08/07/16 02:44 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Remove bolt #3 completely. Remove the belts from the largest pulley first, they will come off easier than the small diameter alternator pulley.
Re: Can't get belts off alternator [Re: xyxxjx] #2126935
08/07/16 02:45 AM
08/07/16 02:45 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Take bolt three out and see if it'll swing in far enough.
If that doesn't work take bolt one out and see if you can push the alternator in enough.
If that doesn't work, cut the belts off and get the right sized ones.
Don't be the exception.
Re: Can't get belts off alternator [Re: xyxxjx] #2126959
08/07/16 05:04 AM
08/07/16 05:04 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Loosening bolt 1 almost all the way did it. It appears the fuel hose from the fuel filter to the carburetor was between the alternator and the engine making it hard to get the belts off. Should that hose be in that location? I'm removing the alternator to get to the fuel pump and filter to replace them.
