I have a '72 Charger Ramcharger hood and the little door ain't workin' I have 15psi (20psi reving) from engine. After going through can, in to the car, through the switch and back out to the the door actuator 8psi (13psi)...Is that enough?
I tried it return spring on/off no difference. If I give the door considerable "help" it works fine. The 8/13 psi is same for each side with the switch on/off and I confirmed when the "open" line has vacuum the "closed" side is at "0" and vice versa
All new parts, most from PG classic including actuator
Thanks in advance
