1974 Satellite Brake problems Need help #2126692
08/06/16 07:23 PM
08/06/16 07:23 PM
St Charles MO
70Coronet500Vert Offline OP
St Charles MO
1974 Satellite, disc/drum car 318.
Today, new steel lines on rear, new rear hose, existing steel line front to rear, existing steel lines MC - prop valve, existing steel lines prop valve to caliper hoses, new hoses to calipers.
Did rear brakes, adjusted tight, not too tight.
Put in new master cylinder (MC). Bench bled MC, installed on car, bled entire car. no air. Have checked several times.
PROBLEM. We get a hard pedal bleeding. Start car, goes to floor, little to no pedal at all. Not spongy, not low, but damn near on floor and barely holds car. Turn car off, brakes will pump back up to hard pedal.
Reading FSM, a troubleshooting step is to pump up brakes, hold, start car. Says brakes should drop a little, then hold. If it does not do this they say replace booster. What they do not say is if the pedal does not fall replace booster, or if the pedal falls too far replace booster, or if either, replace booster. I really dont want to spend $150 on a booster for now reason.
Any other ideas? I have read through all search results on "brakes" and now I am going to search on booster and MC. But maybe one of you guys knows what this is. I could use the help.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2126707
08/06/16 08:04 PM
08/06/16 08:04 PM
check the clearance between the booster pushrod round threaded nub and the bottom of the MC rear piston "thimble". want ~ .020"). you might be able to observe the fluid for any signs of movement when it gets started with a helper or likely pull the MC (4) nuts & pull the MC forward so you can measure
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2126717
08/06/16 08:20 PM
08/06/16 08:20 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
On the pop valve is there anything stinking out besides where the wire for the warning light goes?
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2126750
08/06/16 09:39 PM
08/06/16 09:39 PM
St Charles MO
St Charles MO
On the end, there is a small rod sticking out. Wasnt sure if it should be in or out
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2126800
08/06/16 11:09 PM
08/06/16 11:09 PM
if the rounded nub clearance is OK what I would do is get (2) brass inverted flare plugs from the Edelman cabinet at your parts house & remove the lines from the MC & cap the ports then idle it & if the booster & check valve is fine and the MC is holding pressure & bled out the pedal will be rock hard with virtually no travel and the prob is downstream (air). if you have a pair of junk fittings/lines you can cut the tubing on em right at the fitting and hammer it shut & screw em into the MC to cap em for the same effect which'd save you a trip to your parts house. & if it ain't high and tight then something is fubared with the booster or MC. EDIT on that prop valve pin iirc you hold it out with a clip when bleeding
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2126810
08/06/16 11:21 PM
08/06/16 11:21 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
According to the book, if you use over a certain amount of pressure to bleed the front brakes, that rod should be held to the out position. They even made a special tool for that. At least that's what one of the older service manuals said, so I guess that valve would work the same way in the newer cars.
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2126868
08/07/16 12:40 AM
08/07/16 12:40 AM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Im having the same problem on a 70 cuda Im kinda stumped also. I guess I will look for a rod sticking out.
Re: 1974 Satellite Brake problems Need help [Re: magiccuda] #2126872
08/07/16 12:51 AM
08/07/16 12:51 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
That is in my 71 service manual, but I don't know about 74. You do that if you pressure bleed from the bottom or the top, but not if you just let it gravity bleed. Seems like if it's over 35 pounds or something like that. I take a good quality squirt can with fluid in it and slowly push it up from the wheel into the master cylinder. Of course if something else is wrong this will have nothing to do with that.
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2127016
08/07/16 11:10 AM
08/07/16 11:10 AM
St Charles MO
St Charles MO
Book said gravity bleed OK to ignore pin because under 35psi. Book said ok to ignore pin on manual bleed because over 135psi. Book said use tool to hold pin on a pressure bleed because that is over 35 and under 135 psi. So I did not worry about the pin.
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2127032
08/07/16 11:31 AM
08/07/16 11:31 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Don't worry about the pin.
You stated that you could pump up the brakes with the engine off. You should not have to pump them. It should be tight on the first hit.
It sounds like you still have air in the lines.
Did you bench bleed the MC properly before installation?
I use the little clear hoses that come with aftermarket MCs. The MC gets locked in my bench vise by one of the mounting ears then I take a big phillips head screwdriver that barely fits in the hole and slowly press the piston in until it bottoms. It is allowed to come back VERY slowly and I watch the clear hoses for bubbles. If bubbles get sucked back in towards the port I hold the piston in place and let the bubbles rise to the top of the hoses.
It takes a few minutes to bleed this way but you can be sure the MC is properly bled. The tiniest bit of air will jack with your pressures.
- Stu Harmon
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2127045
08/07/16 11:50 AM
08/07/16 11:50 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Assuming the components are in new/good condition, eliminate the basic possible installation errors: (1) booster to master cylinder rod air gap/adjustment, improperly adjusted this can cause low/no pedal or hard pedal/dragging brakes, you need to adjust any time a replacement master is added to the system
(2) are the front calipers on the correct side of the car?, are the bleeders located at the highest point in their mounting to allow air to be properly bleed?
(3) when bench bleeding the master did you bottom out the piston?, if so you may have damaged the piston O ring(s) by over stroking it, if so, it'll never create/hold pressure once installed in the system
These are just some of the basic problems, but from your description I would tend to think your issue is in the booster to master air gap, I would start there...you need between .020 to .060 max air gap
Re: 1974 Satellite Brake problems Need help [Re: DAYCLONA] #2127046
08/07/16 11:51 AM
08/07/16 11:51 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
to adjust:
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2127052
08/07/16 11:59 AM
08/07/16 11:59 AM
md
mopars4ever Offline
mopars4ever  Offline
md
how do you measure that gap?
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2127063
08/07/16 12:10 PM
08/07/16 12:10 PM
Andrewh Offline
Andrewh  Offline
you can do it a couple of ways, but the easiest to me is to look into the master as you put that master back on. you can see the piston move in the hole inside. I adjust it to see it move then back it off till it doesn't move when I put the mc back on flush.
BUT- lets back up.
Did you only change that steel line? nothing else? Why did you change it?
IF that is the only thing you did, you are just messing your self up checking these other things. IF the brakes worked fine before and you only changed that line you need to be checking things down stream to see if something couldn't handle the change before you start messing up stream again.
Re: 1974 Satellite Brake problems Need help [Re: Andrewh] #2127085
08/07/16 01:03 PM
08/07/16 01:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By Andrewh
BUT- lets back up.
He did change the master cylinder, even if he had the original one in place rebuilt, you still need to check the air gap between the master and booster regardless
Re: 1974 Satellite Brake problems Need help [Re: mopars4ever] #2127091
08/07/16 01:10 PM
08/07/16 01:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Normally I use a set of dial calipers to measure the depth of the bore on the master from the mounting face in the rear of the master, to the bottom of the bore/piston
then measure how much rod protrudes from the master's mounting face on the booster to the tip of the booster's pushrod, then it's just simple math to determine the desired length needed, plus they sell simple go/no go gauges at most auto parts stores like seen below
Re: 1974 Satellite Brake problems Need help [Re: 70Coronet500Vert] #2131813
08/13/16 10:11 AM
08/13/16 10:11 AM
St Charles MO
St Charles MO
So, the master cylinder pushrod was only about 1/2" short!!!! I adjusted it, it is a lot better but I do not know if it is exactly 0.02 gap. Probably could use a little more adjusting.
I used a sharpie on a dowel rod no fancy gauges do I own. It is close. It is better.
Of course, the starter cable laying on the brake line somehow rubbed a hole in the cable insulation and then the starter cable burned a hole in the brake line three days later. Thank god the stuff is not easily flammable.....
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
