Fuel pump installation #2126360
08/06/16 04:50 AM
08/06/16 04:50 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I'm changing the mechanical fuel pump on my 73 charger. Would it be easier to remove the alternator to get to the pump or go in from the bottom? What's the easiest way to deal with the pushrod? Any other good advice appreciated.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
Re: Fuel pump installation [Re: xyxxjx] #2126435
08/06/16 11:27 AM
08/06/16 11:27 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You can undo the lower alt strap and swing the alt up and out of the way on it's main pivot bolt, as far as the rod, just swab it with some heavy grease to hold it up in postion
Re: Fuel pump installation [Re: DAYCLONA] #2126629
08/06/16 05:32 PM
08/06/16 05:32 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Thank you.
