1970 Cuda dash clock. #2126223
08/06/16 12:04 AM
08/06/16 12:04 AM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
I bought a used dashboard clock for my 1970 Cuda and want to test it before I install it in the car. How do you test the clock out of the car? It is from the standard dash.
Re: 1970 Cuda dash clock. [Re: LTLBEE] #2126236
08/06/16 12:17 AM
08/06/16 12:17 AM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
hook up 12 volts and see if its moving... set time and check every hour for a day or 2 and You'll see if it accurate??
Re: 1970 Cuda dash clock. [Re: LTLBEE] #2126237
08/06/16 12:17 AM
08/06/16 12:17 AM
Salinas, CA USA
70swinger340 Offline
Salinas, CA USA
Ground the housing and touch voltage to the terminal
Re: 1970 Cuda dash clock. [Re: 70swinger340] #2126369
08/06/16 08:32 AM
08/06/16 08:32 AM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
Thanks. I'll give it a try
Re: 1970 Cuda dash clock. [Re: ngpSatellite] #2126431
08/06/16 11:23 AM
08/06/16 11:23 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Is the clock also running on reduced voltage from the dash VR?...
I usually use a 6 volt DC lantern battery to check Mopar dash instruments for activation
Re: 1970 Cuda dash clock. [Re: DAYCLONA] #2126482
08/06/16 12:21 PM
08/06/16 12:21 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
No a clock is tapped into a constant 12v. Any they have that wierd mechanical electromagnetic device that periodically rewinds the spring. The new solid state design is the way to go, but you lose the stop-go second hand. It becomes a sweep.
