OE Leaf Spring Clamp #2123649
08/02/16 08:52 PM
08/02/16 08:52 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Looking at OE 024 & 034 70 E-body leaf spring clamps. It seems that the repro clamps are clear / silver zinc plated, which are way too shiny in my eyes. Should the clamps be natural steel? Does anyone make or sell the correct looking ones?
TIA Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: OE Leaf Spring Clamp [Re: VCODE] #2123684
08/02/16 09:58 PM
08/02/16 09:58 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Natural steel, and left that way if the leaf springs were left unpainted. If the springs are painted black, so should the clamps, most agree the entire spring assemblies were dipped in paint.
Re: OE Leaf Spring Clamp [Re: VCODE] #2123695
08/02/16 10:18 PM
08/02/16 10:18 PM
blewbyu Online content
blewbyu  Online Content
So are you saying some springs and clamps were unpainted and some painted? I am getting ready to work on my rear end and it looks like they were unpainted on my 69 Dart.
Re: OE Leaf Spring Clamp [Re: blewbyu] #2123700
08/02/16 10:20 PM
08/02/16 10:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Look between your spring leafs for paint residue when you take them out.
Re: OE Leaf Spring Clamp [Re: blewbyu] #2123708
08/02/16 10:32 PM
08/02/16 10:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, some were painted, and some were not. The paint was very thin and often deteriorated and was replaced with rust rather quickly so before deciding, as Barry said, look VERY closely between the springs and other protected areas for remnants of paint.
Re: OE Leaf Spring Clamp [Re: VCODE] #2123825
08/03/16 01:47 AM
08/03/16 01:47 AM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Give a choice what do you think looks better on a A12 road runner?
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: OE Leaf Spring Clamp [Re: Q5_Ed] #2123890
08/03/16 09:56 AM
08/03/16 09:56 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Thanks for the Info. Where can I get the correct natural clamps. The repro ones don't look correct for unpainted springs
Bob
Re: OE Leaf Spring Clamp [Re: VCODE] #2123908
08/03/16 10:39 AM
08/03/16 10:39 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't know of a source. You could just give them a quick dip the plated versions in muratic acid to remove the plating, rinse them off really well then buff them with 0000 steel wool to a natural sheen, finish with a good rust prevention product.
Re: OE Leaf Spring Clamp [Re: ScottSmith_Harms] #2124120
08/03/16 04:04 PM
08/03/16 04:04 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Yes Scott, I was going to try something like that or maybe media blast then RPM
Thanks Bob
Re: OE Leaf Spring Clamp [Re: VCODE] #2125763
08/05/16 03:09 PM
08/05/16 03:09 PM
OhiO
drgordi Offline
drgordi  Offline
OhiO
The bad thing about blasting is it leaves the blasted look instead of the natural finish you are looking for.
Re: OE Leaf Spring Clamp [Re: drgordi] #2125816
08/05/16 03:59 PM
08/05/16 03:59 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
You are right. The clamp that is being sold does not seem to be steel.
I have some things I am thinking of, yet you know if it works out
Thanks Bob
Re: OE Leaf Spring Clamp [Re: drgordi] #2125855
08/05/16 04:44 PM
08/05/16 04:44 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
I think it all depends on the kind of media you use. Walnut shells and glass beads I don't think leave that impregnated look like black oxide or whatever that stuff called Black Beauty is.
inherited a 69 roadrunner from my grand pop.
Re: OE Leaf Spring Clamp [Re: VCODE] #2125869
08/05/16 05:11 PM
08/05/16 05:11 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
frank b has and makes the natural ones. plus he has real zinc interliners, not made out of sheet metal. ronnie
Re: OE Leaf Spring Clamp [Re: 1969ronnie] #2125910
08/05/16 06:12 PM
08/05/16 06:12 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
OK, I called Frank but may need to wait till Monday. He must be busy.
Thanks Bob
Re: OE Leaf Spring Clamp [Re: VCODE] #2126029
08/05/16 08:03 PM
08/05/16 08:03 PM
md
mopars4ever Offline
mopars4ever  Offline
md
If they are steel, glass bead em and then hit them with some steel wool and they will look natural.
Re: OE Leaf Spring Clamp [Re: VCODE] #2126085
08/05/16 09:13 PM
08/05/16 09:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I forgot about Frank having them, he won't let you down.
Re: OE Leaf Spring Clamp [Re: ScottSmith_Harms] #2126131
08/05/16 10:11 PM
08/05/16 10:11 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Tried calling Frank, he must be busy. I will call on monday I am sure he will have the right clamp.
Thanks everyone
Bob
Re: OE Leaf Spring Clamp [Re: VCODE] #2126137
08/05/16 10:17 PM
08/05/16 10:17 PM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
I purchased the entire rebuild kit from frank.
For my 023/034 springs
Spot on!!
Very happy
Bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
