A Body Vent Window Seal/Weatherstip #2125518
08/05/16 10:38 AM
08/05/16 10:38 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Does anyone repro the seal/strip that attaches to the vent window to seal against the main window and has the little piece at the top for the glass? See the pic to see where I mean.
I've looked on the websites of the major parts suppliers and do not see this piece listed.
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2125527
08/05/16 10:50 AM
08/05/16 10:50 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Call Dixie. I bet they'll know if it is available.
Master, again and still
Re: A Body Vent Window Seal/Weatherstip [Re: DaveRS23] #2125538
08/05/16 10:59 AM
08/05/16 10:59 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
https://dantesparts.com/?s=vent+window&post_type=product&tags=1&ixwps=1
Sorry I though you meant the seal. You are talking about the slide strip with the white plastic holder or the felt channel with the rubber tip? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2125567
08/05/16 11:38 AM
08/05/16 11:38 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I am talking about whatever fits inside the vent window frame and has the rounded rubber tip that fits the small curve in the main window. The guy who did the chrome threw them away on me.
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2125618
08/05/16 12:14 PM
08/05/16 12:14 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Visit your local Chrysler Parts counter and order part number 2932230 for the original part. They retail in the $71.00 range for the one piece mylar slide and clips. There is a reproduction on the market now that retails in the $100 range for a pair.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2125643
08/05/16 12:40 PM
08/05/16 12:40 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks! I picked up a set of those and they are installed. I thought there was another piece that had the small rubber tip for the curve in the door glass. I didn't know it was a separate piece. I need to go back to e-bodies!! LOL
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2125655
08/05/16 12:53 PM
08/05/16 12:53 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Looking at the picture, you will need the small sort of triangle hard rubber stop that goes at the very top of the vent window frame. I sent you a private message as well. Good luck.
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2125659
08/05/16 12:57 PM
08/05/16 12:57 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Yes! That's what I need!
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2125796
08/05/16 03:46 PM
08/05/16 03:46 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The good thing is that those pieces are the same from 67-72 2-door hardtops, and probably others as well, shouldn't be to difficult to find good used.
A-Body's RULE!
Re: A Body Vent Window Seal/Weatherstip [Re: Rhinodart] #2125809
08/05/16 03:54 PM
08/05/16 03:54 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Abe Lincoln
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2126222
08/06/16 12:01 AM
08/06/16 12:01 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Looks like this is what you need.
(Am I the only one who takes pics of these things?)
23-9 Doors.R vent glass12.jpg23-9 Doors.R vent glass15.jpg23-9 Doors.R vent glass18.jpg
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2126374
08/06/16 09:12 AM
08/06/16 09:12 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Yes - that is it!
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2126550
08/06/16 02:22 PM
08/06/16 02:22 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
So you just need the rubber tip or both that and the felt channel?
A-Body's RULE!
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2127915
08/08/16 02:52 PM
08/08/16 02:52 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Just the rubber tip. I installed new channel seals.
Re: A Body Vent Window Seal/Weatherstip [Re: Erik] #2128251
08/08/16 10:39 PM
08/08/16 10:39 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Not hard to find.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
