Supercharger vs, Turbocharger Is one harder on an engine? #2125168
08/04/16 08:13 PM
08/04/16 08:13 PM
USA
hudsonhornet7x Offline OP
USA
For forced induction application, is one easier on internal engine parts than another? Or is boost just boost no matter how you get it?
For this instance lets say you have a 750 horsepower goal, so nothing extraordinary.
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: hudsonhornet7x] #2125217
08/04/16 09:28 PM
08/04/16 09:28 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Turbo is easiest on engine
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: hudsonhornet7x] #2125235
08/04/16 10:00 PM
08/04/16 10:00 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
subscribed
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: hudsonhornet7x] #2125277
08/04/16 10:56 PM
08/04/16 10:56 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Supercharger takes power to drive. So whatever that load is, the crank sees fwhp+blower drive power in reality.
Turbo cars are notoriously hard on exhaust valves.
Roots/Whipple can make wicked low end torque like a turbo which is harder on parts then the centrifugal blowers do because they don't make peak boost until peak RPM.
Both can be hard on pistons and headgaskets if you miss the tuneup.
Both are much more forgiving on the motor then NA or nitrous of the same power because they have lower peak cylinder pressures. They just hold the pressure longer and further away from TDC which is easy on parts.
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: hudsonhornet7x] #2125282
08/04/16 11:02 PM
08/04/16 11:02 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Turbos are easier on tires and drivetrain.
Mopar to the bone!!!
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: hudsonhornet7x] #2125291
08/04/16 11:14 PM
08/04/16 11:14 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I beg to differ on the drivetrain!
Mine has killed the front planet, rolled a sprag (with a LBA valve body), and sheared the yoke right off a 8 3/4"...now this.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2121136
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: hudsonhornet7x] #2125347
08/05/16 12:01 AM
08/05/16 12:01 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Miss the tuneup and the blower or turbo can really mess up your day. My 'mild' 318 has so far eaten 4 pistons. In both cases it was real fun for a couple seconds. Note to self, you've got to do a turbo 440.
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: hudsonhornet7x] #2125348
08/05/16 12:03 AM
08/05/16 12:03 AM
USA
USA
I was thinking turbo with a self learning efi like fitech. Any objections?
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: hudsonhornet7x] #2125377
08/05/16 12:45 AM
08/05/16 12:45 AM
If it is for street use make sure and use a intercooler and monitor the intake manifold inlet temps thumbs twocents
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: hudsonhornet7x] #2125524
08/05/16 10:42 AM
08/05/16 10:42 AM
New York
polyspheric Offline
polyspheric  Offline
New York
750 hp can use a turbo as small as 64mm if it's a modern design like the Precision CEA Gen-2.
Choosing that microwave-size 100mm for highest peak power is generally a mistake, you can't make boost for launch without really buzzing the engine against the rev limiter. I have small turbos with only about 500 hp, with boost as low as 2,000 rpm.
Once you pick a compressor size, next is to see what someone with a similar engine uses for A/R: the general idea is small engine, small A/R. IDK of any math that will work here; Precision will give you a good choice if you buy from them.
For many apps there is an OEM iron manifold choice that will produce 95% of "tuned" (= $$$) header results for 10% of the price. Many LSX with iron manifolds: 1,000 hp.
What transmission?
Boffin Emeritus
Re: Supercharger vs, Turbocharger Is one harder on an engine? [Re: GTS340] #2125713
08/05/16 01:57 PM
08/05/16 01:57 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
the reason being was I always thought, the piston, rod, crank on the up stroke/exhaust are always working against exhaust pressure.
