Big Block Plug Wire Routing #2125224
08/04/16 08:48 PM
08/04/16 08:48 PM
SW CO
HemiSportFury Offline OP
SW CO
I've been scratching my head on what is the best routing for RB/BB plug wires when using headers. The number 1 and 2 header tubes go above #3 and #4 and then down between 5-7 and 6-8. The front two plug wires on both sides are pretty easy to route from below the front tube, but the back cylinders are more of a challenge. It looks like the best route would be over the top of the valve covers. If so, how do you support them and keep them off the header tubes? The other option is to route them wide of the headers and lay them against/on top of the steering box and shock towers. This does not look very "neat" to me.
How about showing some pictures of how you have routed and supported your plug wires to give me some ideas. I'd like the plug wires to look neat and orderly, but the stock routing is not an option with headers.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2125249
08/04/16 09:18 PM
08/04/16 09:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a set of looms from Summit.I think they are something like RJS ot like that.They go on top of the vcover at the bottom and wires go from 4 to 1 in the back.they are aluminum and do a nice job.Ran them on our cars all with headers.last set of wires was on 15 years.I did run a thermal sock on 7 because it was close.My 2 inch TTIs fit nicely with the looms and Taylor stock 440 lug wires.Rocky
Chrysler Firepower
Re: Big Block Plug Wire Routing [Re: therocks] #2125271
08/04/16 09:46 PM
08/04/16 09:46 PM
SW CO
SW CO
Do you have a picture of that setup?
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2125313
08/04/16 10:29 PM
08/04/16 10:29 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have always run mine around the front and under.
71 Barracuda
70 Valiant
63 Plymouth
1963 Plymouth Max Wedge
1971 Barracuda
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2125472
08/05/16 03:03 AM
08/05/16 03:03 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Not mine, but very cool. Number 8 wire needs to be a couple inches longer. They are sold two different ways, horizontal or vertical.
https://www.summitracing.com/parts/rnm-1104p/overview/make/dodge
R&M%20Specialies%20Spark%20Plug%20Wire%20Looms-003.jpgR&M%20Specialies%20Spark%20Plug%20Wire%20Looms-004.jpgR&M%20Specialies%20Spark%20Plug%20Wire%20Looms-005.jpgR&M%20Specialies%20Spark%20Plug%20Wire%20Looms-002.jpg
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2125473
08/05/16 03:05 AM
08/05/16 03:05 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
More.
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2125481
08/05/16 06:23 AM
08/05/16 06:23 AM
None
71rm23 Offline
71rm23  Offline
None
In relation to the OP's question: Does anyone know where to get the wire #'s for the wires? I think they clip on to the wire
Re: Big Block Plug Wire Routing [Re: therocks] #2125491
08/05/16 07:52 AM
08/05/16 07:52 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
same here. up and over. i've got socks on all of them cause i got a good deal on ebay for a set of 8
Re: Big Block Plug Wire Routing [Re: mikemee1331] #2125553
08/05/16 10:17 AM
08/05/16 10:17 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Mine on a 70 383...
I made the small brackets for under the valve cover bolts to tuck the wires into.
...FAFO...
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2125745
08/05/16 01:50 PM
08/05/16 01:50 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Carnut has the pic posted.The looms are super nice.Mine have been on well over 15 years and they come with spacers to raise or lower the loom.Wires stay nice and tight in the holders with allen screws.Well worth the $$$.They even come in colors.We have run them on BBs and SBs with headers. Rocky
Chrysler Firepower
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2126097
08/05/16 08:27 PM
08/05/16 08:27 PM
SW CO
SW CO
Thanks for posting all the pictures. You guys do nice work. This will give me some ideas if I get a chance to work on the car this weekend.
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2126269
08/05/16 11:59 PM
08/05/16 11:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
For me it depends on the wires and if the car has headers and what brand of headers. On my sons 400 with CPPA headers we ran the #5 & #7 wires along the intake at the top of the valve cover and around as the #7 wire was a 90 degree end. So was the #8 wire which we also ran along the intake at the top of the valve cover. Ron
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2126274
08/06/16 12:00 AM
08/06/16 12:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On my 440/493 in my 63 with TTI headers the Firecore wires are all 45 degree ends and they woked good running all of them around the front of the eng and along the side. Ron
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2126328
08/06/16 02:12 AM
08/06/16 02:12 AM
None
71rm23 Offline
71rm23  Offline
None
383man-They both look good! Least it gives me some ideas as well. I need to source the wire identifiers (number for each wire)
Re: Big Block Plug Wire Routing [Re: 71rm23] #2126657
08/06/16 05:21 PM
08/06/16 05:21 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
tNot certain now, perhaps it was Summit. Check EBay or Amazon.
Re: Big Block Plug Wire Routing [Re: Sxrxrnr] #2126694
08/06/16 06:27 PM
08/06/16 06:27 PM
None
71rm23 Offline
71rm23  Offline
None
Thanks and your engine compartment looks good!
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2126925
08/07/16 01:14 AM
08/07/16 01:14 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The best I can tell you is on my sons Dart (the blue wires) they are Taylor wires. And the black wires on my 63 are Firecore. I like both as they both worked good for us. And thanks for the kind words.
Ron
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2128055
08/08/16 05:28 PM
08/08/16 05:28 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
We sell the wire markers..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Big Block Plug Wire Routing [Re: sunroofgtx] #2140748
08/25/16 06:06 PM
08/25/16 06:06 PM
SW CO
SW CO
Thought I should update this post on what I ended up doing with my plug wires. I appreciate all the people that took the time to post a picture of their engines. It gave me some good ideas. I wound up routing the front two cylinders on both sides below the headers, and the back two above the headers. I put heat sleeves on 5 & 6 since they run fairly close to the header tubes. I used Spectra wire separators and made aluminum brackets that mounted to the valve cover bolts. The Taylor universal wire set was plenty long to allow routing of your choice. I'm happy with the result for what I have invested in it. Thanks for your help.
PS Don't mind the burnt header paint. That's a victim of breaking in a new cam. Probably take them off this winter and try again.
Re: Big Block Plug Wire Routing [Re: HemiSportFury] #2140931
08/25/16 09:43 PM
08/25/16 09:43 PM
None
71rm23 Offline
71rm23  Offline
None
Looks good, HemiSport. It gives me some ideas as well too
