checking the sprage? #212522
02/02/09 11:25 PM
02/02/09 11:25 PM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
If you unloaded the trans during launch would you check the sprage of your 727?
2800 RPM launch, limiter set at 6800, rear broke at the go light.
4bbl If you can't hear it coming what's the point.......
Re: checking the sprage? [Re: 4bbl] #212523
02/02/09 11:28 PM
02/02/09 11:28 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Does your VB have a LBA?
Re: checking the sprage? [Re: 4bbl] #212524
02/02/09 11:31 PM
02/02/09 11:31 PM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
check it
Re: checking the sprage? [Re: MoparPitBull] #212525
02/02/09 11:36 PM
02/02/09 11:36 PM
South Dakota
dakotahotrodder Offline
South Dakota
check it, right after you re-weld your spring perches! I'd also box in the ends of your spring perches. Wade
Re: checking the sprage? [Re: dakotahotrodder] #212526
02/03/09 12:44 AM
02/03/09 12:44 AM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
Gave me a chuckle Wade. I did the re-welding and the boxing you suggested.
Buying the blanket too.
Suppose I better check the sprage, but will I know what I am looking for when I see it?
Is the bottom of your right foot itching too?
Re: checking the sprage? [Re: 4bbl] #212527
02/03/09 01:55 AM
02/03/09 01:55 AM
I have broke three rear ends on the starting line in the last 2 years..Everytime the sprag in the 727 broke...
Re: checking the sprage? [Re: 4bbl] #212528
02/03/09 07:34 AM
02/03/09 07:34 AM
South Dakota
South Dakota
Itching indeed. I thought I had a picture of a sprag installed during assembly, but I can't find it. Maybe someone will post one?
Re: checking the sprage? [Re: dakotahotrodder] #212529
02/03/09 10:30 AM
02/03/09 10:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sprag isn't the only thing to check , a friend boke his rear , just as the roller starting to roll over and jamb the rear drum he got lucky and the mainshaft snapped off just past the splines for the front planet .
Re: checking the sprage? [Re: JohnRR] #212530
02/03/09 06:45 PM
02/03/09 06:45 PM
NC
440Jim Offline
440Jim  Offline
NC
In case you need more convincing, check your sprag. It happened to me and the sprag was rolled.
Here is a pic of a normal sprag. When you remove the rear drum, do so slowly and carefully so you don't make the rollers come out during disassembly. The rear drum engages the inner race in the picture, and you could disturb it while removing the drum.
Look for springs/rollers out of position, and the little tabs that the springs press againts could be bent over.
Re: checking the sprage? [Re: 440Jim] #212531
02/03/09 09:40 PM
02/03/09 09:40 PM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
Thanks all. I'll start by pulling the trans and go from there.
