How do you? Trim removal on a '67 Charger #212477
02/02/09 11:04 PM
02/02/09 11:04 PM
Kansas City
Racewriter Offline OP
Kansas City
Hello all - first post here on the forum, and I have my hand out for help. Starting restoration/restification on my '67 Charger, and I don't know how to remove the aluminum fender top trim or the rocker trim. I'm guessing that the rocker trim has clips that rotate into position to hold the trim, so you rotate them back to remove it (am I right?), but what about the fender top trim? All of the trim is in good condition, so not screwing it up is a high priority. Thanks.
Re: How do you? Trim removal on a '67 Charger [Re: Racewriter] #212478
02/04/09 08:37 AM
02/04/09 08:37 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
There are studs and nuts on the end pieces that have to come off. For the rear the j-shaped parts on the back come off first, and the gently pry the rest off. Take your time and locate the clips. Pry at the clip. Some come off pretty easy, some not so easy. It's soft aluminum so be careful.
Re: How do you? Trim removal on a '67 Charger [Re: bobby66] #212479
02/05/09 11:57 AM
02/05/09 11:57 AM
Kansas City
Kansas City
Thanks - I appreciate it.
