Lets Talk Break In Oil
#2124365
08/03/16 10:15 PM
08/03/16 10:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This is the first time I have run a solid FT cam in over 20+ years... everything has been a roller.. so my question is.. what is the best break in oil.. and I assume during break in you still add zinc additive then use zinc in every oil change... I greased everything with the break in grease while putting it together.. all the lobes and lifters... I also assume you can use regular oil with the additive after the break in thanks EDIT And I did remove the inner springs
Re: Lets Talk Break In Oil
[Re: MR_P_BODY]
#2124416
08/03/16 10:54 PM
08/03/16 10:54 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I am now gun shy about oil. I took out 2 wiped hydraulic cams out of my engines last year. One was a new comp cams and another was an older mopar purple shaft cam.
Next week I hope to fire up my new comp cams hydraulic lifer cam engine. I am going with the Driven (Joe Gibbs) break in oil and crossing my fingers. I need to ask Driven if I should add the Comp Cams additive or not.
[Re: markz528]
#2124434
08/03/16 11:13 PM
08/03/16 11:13 PM
MR_P_BODY
Should extra zinc be added with the break in oil or is there plenty of zinc in it already... I've gone to all this work and I dont want a failure now
[Re: MR_P_BODY]
#2124464
08/03/16 11:44 PM
08/03/16 11:44 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The local shop that I deal with for machine work switched from Brad Penn Break in oil to Lucus break in oil after they started having some issues. So far so good.
[Re: MR_P_BODY]
#2124530
08/04/16 12:47 AM
08/04/16 12:47 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I don't have a flat tapped but used Lucas 30wt. Got a 2.5 gallon jug of it. Seemed like the rings seated on the first drive.
Mopar to the bone!!!
[Re: 72Swinger]
#2124564
08/04/16 01:32 AM
08/04/16 01:32 AM
MR_P_BODY
I don't have a flat tapped but used Lucas 30wt. Got a 2.5 gallon jug of it. Seemed like the rings seated on the first drive. This is just a cam change... engine has about 850 miles on it but the tight LSA didnt like the EFI or should I say it the other way around
[Re: calrobb2000]
#2124584
08/04/16 02:08 AM
08/04/16 02:08 AM
RapidRobert
OT, I would confirm the lifters are free to rotate (Hughes "thunk" test) & the usual stuff that you are aware of more than I am, mixture/timing/immediate startup/goosing the throttle.
