Page 2 of 3 1 2 3
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2123674
08/02/16 09:33 PM
08/02/16 09:33 PM
Alberta
440_Offroader Offline
Alberta
My powerwagon was exactly like that... big puff of smoke on start up. Pull the valve covers and see if the seals are even there. Some valve seals and valve cover gaskets are cheap. I'd go with poorboys suggestion with a compression test first, just to make sure the cylinders are good.
Re: Dang it, I broke it. Do I fix or move on....... [Re: 440_Offroader] #2123801
08/03/16 01:13 AM
08/03/16 01:13 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
That is the first thing you should do (1) Compression test - dry (2) Compression test - wet (2 squirts of oil in each cylinder before testing) this will determine good rings or bad, if no change and still big variation in numbers then you have a valve sealing issue. Testing is cheap and will prove a lot.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Dang it, I broke it. Do I fix or move on....... [Re: Polarapete] #2123905
08/03/16 10:31 AM
08/03/16 10:31 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I'd say you shatter a ring or two, when I did that it started using oil and smoked... work
JB Rhinehart, Realist
A-Body's RULE!
Re: Dang it, I broke it. Do I fix or move on....... [Re: Rhinodart] #2124182
08/03/16 06:05 PM
08/03/16 06:05 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yea, I did that in my younger days. Bought a nice big block car from a little old lady, then my young butt started hot rodding it. In very short order it started smoking. My boss informed me that a ridge forms at the top of the cylinder above the top ring travel. When you dramatically increase engine rpm over what it usually ran, the rings travel up the cylinder walls a couple thousands and the rings hit that ridge and break the rings, or the pistons around the rings. OOPS!
The more something costs you, the better you remember the lesson. Gene
Re: Dang it, I broke it. Do I fix or move on....... [Re: poorboy] #2125324
08/04/16 11:36 PM
08/04/16 11:36 PM
Between Houston & Galveston TX
SattyNoCar Online work OP
SattyNoCar  Online Work OP
I won't be able to diagnose it until this weekend, but, I noticed something different today.....
The PCV valve doesn't buzz anymore. confused
Back in April I posted here asking why it would buzz, most people felt it was 'normal'.
Pulled the PCV valve out tonite, its not full of oil, and still has strong vacuum.
shruggy
Saturday can't get here soon enough...... frowwn
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2125399
08/05/16 01:09 AM
08/05/16 01:09 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
How much blowby does it have with the PCV valve pulled?
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Dang it, I broke it. Do I fix or move on....... [Re: 71yelladustr] #2127077
08/07/16 12:44 PM
08/07/16 12:44 PM
OK, here we go. My gauge reads in 5 lbs increments, so slight differences are hard to put an exact number to.
Cyl 1: 160
Cyl 3: 155
Cyl 5: 155
Cyl 2: 160
Cyl 4: 165 (checked this one twice dry, same reading)
Cyl 6: 155
A squirt of oil had minimal affect.
Here's a pic of the plugs:
Nothing looks 'wrong'.
One thing I did notice is I smelled gas quite a bit on the plugs, even though the truck had been sitting for about 10 hrs without being started.
Same thing when I was doing the tests, I could smell gas. I had the fuel pump relay unplugged, the coil (power) wire unplugged, and the throttle body held open during the tests.
It smelled enough that my wife asked if I had spilled gas.
Smelling the oil, it just smelled 'used', no strong gas smell.
I'm leaning towards it being the valve stem seal(s), but, the fuel smell has me concerned.
Ideas?
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2127087
08/07/16 01:06 PM
08/07/16 01:06 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Those are good numbers and nice looking plugs. Have you looked into the intake to see if there's oil in the bottom of the plenum? Also see how much vacum it pulls at idle, a blown plenum gasket should show low vacum
Re: Dang it, I broke it. Do I fix or move on....... [Re: WO23Coronet] #2127185
08/07/16 03:49 PM
08/07/16 03:49 PM
I couldn't find my vacuum gauge, so I have no readings.
I just have this unscientific video.... blush
PCV vacuum
Oh, and the 'buzz' from the PCV returned yesterday.
One more video showing the V6 at idle... idling V6 zzzzzz
Like I said previously, it runs no different. It just smokes at first fire and uses oil now. frowwn
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2127218
08/07/16 04:43 PM
08/07/16 04:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Still sounds like valve stem seals or intake.
Re: Dang it, I broke it. Do I fix or move on....... [Re: stumpy] #2127230
08/07/16 05:04 PM
08/07/16 05:04 PM
I agree. Just to dang hot out right now to dig in. panic
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2127623
08/08/16 01:33 AM
08/08/16 01:33 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
It takes a lot of extra oil usage to add up to the cost of most repairs. Think maybe I would give it a fresh oil & filter change, and track exactly how much oil it is actually using. Back in the old days, Chrysler said a quart in 500 miles was acceptable, even in a new motor! From my perspective, a quart in 1,000 miles is borderline excessive.
When you have to add oil between gas fill ups, I believe the oil consumption has exceeded excessive, and its time to do something.
Most of my higher mileage Mopar motors have given a puff of smoke when they start. At least I know they are getting upper cylinder lubrication. Gene
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2127675
08/08/16 08:17 AM
08/08/16 08:17 AM
places
79powerwagon Offline
places
At start up, SMOKE or STEAM?
As I said earlier, it takes MANY $3.00 quarts of oil to equal a quality repair to rid the SMOKE. Even at a qt every 1000 miles, and say $300.00 to fix seal, that's 100,000 miles of driving. Just sayin'... wink
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2127770
08/08/16 12:03 PM
08/08/16 12:03 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Sounds exactly like valve stem seals. Probably not to hard of a job to do this fall or winter.
68 Barracuda Formula S 340
Re: Dang it, I broke it. Do I fix or move on....... [Re: Bad340fish] #2128263
08/08/16 10:55 PM
08/08/16 10:55 PM
Oil consumption.....
It's definitely using more at freeway speeds.
Took the truck down to West Beach (Galveston) yesterday. Checked the oil before leaving, dead on the fill line.
I drove approx. 90 miles round trip, 30 of which were slower 'in town' speeds.
Checked oil a few hrs after I got home, it was down to the add line.
Yes, I've had a few cars that burned WAY more oil, but, to go to this much use from less than half a qt in 3500+ miles is a bit of a shock .
On a side note, I didn't have a full tank of gas so I couldn't calculate the MPG, but, the truck used about a 1/4 tank to cover those 90 miles.
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2128681
08/09/16 01:55 PM
08/09/16 01:55 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
You hear any pinging on the highway cruise?
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2128883
08/09/16 07:37 PM
08/09/16 07:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
With the compression numbers you have, I think I would be looking at an intake gasket failure, either the bottom gasket, or the actual intake gaskets. Its got to be pulling oil into the combustion process, the compression numbers you have means its probably not coming by the rings, and that is a lot of oil coming through the valve guides, even if the seals are nearly gone.
Two other possibilities come to mind.
1) Somehow the oil returns to the pan got partly plugged up and the oil is sitting up in the valve covers.
2) Oil is running out on the ground from someplace, Oil sending unit maybe? Gene
Re: Dang it, I broke it. Do I fix or move on....... [Re: poorboy] #2128984
08/09/16 10:12 PM
08/09/16 10:12 PM
I don't hear any pinging at hwy speed, or any speed for that matter....
There's no puddles under the truck or on the engine. It just looks like a typical high mileage piece, no excessive oil on the engine anywhere.
shruggy
I'm just gonna stick close to home with it until this heat breaks and I can dig into it.
Thanks everyone. beer
Re: Dang it, I broke it. Do I fix or move on....... [Re: SattyNoCar] #2129031
08/09/16 10:49 PM
08/09/16 10:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Like WO23 asked " Have you looked into the intake to see if there's oil in the bottom of the plenum?"
Re: Dang it, I broke it. Do I fix or move on....... [Re: stumpy] #2129113
08/10/16 12:05 AM
08/10/16 12:05 AM
I took a look Sunday, it doesn't look as clean as it did, but it doesn't look wet either. shruggy
Oh, and here's a shot of where I always park my truck at home.....not a drop on the ground.
Page 2 of 3 1 2 3
