92 Dodge Stealth RT Turbo question #2123965
08/03/16 12:32 PM
08/03/16 12:32 PM
Oklahoma City OK
Cudajon Offline OP
Cudajon  Offline OP
Oklahoma City OK
Need to replace the A/C Compressor but they don't make a replacement only rebuild the old ones. Anybody run into this problem? What did you use? Will the 94 (Kit MSC105CF Four Seasons [Rock Auto]) work?
Re: 92 Dodge Stealth RT Turbo question [Re: Cudajon] #2124002
08/03/16 01:13 PM
08/03/16 01:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Rock auto lists an a/c compressor & component kit under four seasons TSR2116, comes with receiver drier(which you'll have to change if you want warranty on your compressor) and expansion valve. Doesn't say you have to send your old one in first.
Not exactly cheap though. I'd be temped to snag a compressor from the junkyard for something else as long as the bolt mounting pattern is the same, then have the connectors from the donor cut and welded on.
