Engine Vin Question
#2123664
08/02/16 09:17 PM
08/02/16 09:17 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I just pulled the 340 engine out of my 69 Valiant to rebuild, now that I can see the VIN on the block is there a way to tell what car it originally came out of?
A new iron curtain drawn across the 49th parallel
Re: Engine Vin Question
[Re: 67autocross]
#2123699
08/02/16 10:20 PM
08/02/16 10:20 PM
67autocross
Manitoba Canada
So it's out of a 71 that was built in Hamtramck....A or E body, is there a way to find the exact car? I'm just curious about it nothing more if it's a bunch of trouble.
[Re: 67autocross]
#2124011
08/03/16 01:27 PM
08/03/16 01:27 PM
67autocross
Manitoba Canada
Numbers on the front are 6 29 70. I would also guess that the car it is out of was from around Winnipeg
[Re: 67autocross]
#2124043
08/03/16 02:17 PM
08/03/16 02:17 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
No, numbers are on the front of the block, driver's side, just below the deck surface.
[Re: 67autocross]
#2124515
08/04/16 12:26 AM
08/04/16 12:26 AM
67autocross
Manitoba Canada
I would say the engine has always been around Winnipeg, just wanted to see if it was out of a 71 Swinger 340
[Re: 67autocross]
#2124537
08/04/16 01:01 AM
08/04/16 01:01 AM
Posts: 2,083 CA
crackedback
CA
I would say the engine has always been around Winnipeg, just wanted to see if it was out of a 71 Swinger 340 Weren't all the 71-72 Swinger 340's built in Windsor, Plant Code "R"? So that would preclude this one being from the Hammy plant.
[Re: crackedback]
#2124948
08/04/16 04:12 PM
08/04/16 04:12 PM
67autocross
Manitoba Canada
I would say the engine has always been around Winnipeg, just wanted to see if it was out of a 71 Swinger 340 Weren't all the 71-72 Swinger 340's built in Windsor, Plant Code "R"? So that would preclude this one being from the Hammy plant. I have no idea about numbers or VIN's , this is the 3rd 340 I have owned and just wanted to see if someone could tell me what car it came out off originally. Thanks' for all the reply's !
