Wheel and Tire Size Recommendations Wanted - 69 A-Body #2122630
08/01/16 02:28 PM
08/01/16 02:28 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I need to purchase some wheels and tires for my 69 Dart (340 stroker/727). The vehicle retains the stock 4" Bolt pattern (manual drum brake setup). It has an 8.75 rear axle with a 3.91 gear ratio. The rear springs have not been relocated inboard, so I have stock wheel well clearances.
I'm considering putting a set of 15" steel wheels in the rear (with dog dish hub caps) and a narrow set of wheels up front. Any recommendations? 15"X6" or 15"X7"? Tire recommendations (brand/size)?
Thoughts for up front?
Lately, I've seen vehicles with Cragar or American Racing wheels up front (15"X4.5") and steel wheels in the rear. (M/T ET Front or Sportsman)
The car will not see excessive amounts of road driving just to local events or trailed to Mopar events at track.
Re: Wheel and Tire Size Recommendations Wanted - 69 A-Body [Re: vinnyd76] #2122727
08/01/16 04:24 PM
08/01/16 04:24 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
15x7 wheel with 4.25" of backspacing and a 235/60-15 tire should be fine in the rear.
Re: Wheel and Tire Size Recommendations Wanted - 69 A-Body [Re: vinnyd76] #2129278
08/10/16 09:34 AM
08/10/16 09:34 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
15 x 6 and 15 x 7 should work nicely....
Frank
Re: Wheel and Tire Size Recommendations Wanted - 69 A-Body [Re: vinnyd76] #2129871
08/10/16 10:26 PM
08/10/16 10:26 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
i went with a 15x7 on the rear of our dart. have 4.5" backspace and wish i had gone 4.75 backspace.. i have bog bolt axles and all though which i think makes it a hair wider then a small bolt set up.. 4.5 back space would fit no problem abd 4.75" backspace may fit well.. i went with a 225/60-15 tire..
here is how much room i have on both sides....
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Wheel and Tire Size Recommendations Wanted - 69 A-Body [Re: abodyjoe] #2130443
08/11/16 05:37 PM
08/11/16 05:37 PM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
Nice fit, what are those wheels off of or did you order a set?
Re: Wheel and Tire Size Recommendations Wanted - 69 A-Body [Re: Neil] #2131602
08/12/16 11:18 PM
08/12/16 11:18 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
x2 up
