Re: 383 Timing woes
[Re: Paul G]
#2122684
08/01/16 03:32 PM
08/01/16 03:32 PM
RapidRobert
I'm assuming the engine sound stays the same (timing ain't changing) but it is an electrical/timing light issue? is this an MSD/dialback light? otherwise you might flip the clamp that goes around the plug wire & try clamping it to #6 plug wire & on both ways make sure it is away from nearby plug wires that can crossfire
Re: 383 Timing woes
[Re: Paul G]
#2122982
08/01/16 10:41 PM
08/01/16 10:41 PM
RapidRobert
the end play is a non issue. what is your initial? on ported or manifold? rebuilt with same cam or hotter cam? did it run OK before but was rebuilt cuz it was tired? same dist? more info please #1 WHAT items/parts were changed in the rebuild other than normal stuff? EDIT & settings
Re: 383 Timing woes
[Re: topside]
#2123577
08/02/16 06:42 PM
08/02/16 06:42 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Maybe a vacuum leak at the intake?
Abe Lincoln
Re: 383 Timing woes
[Re: topside]
#2123601
08/02/16 07:26 PM
08/02/16 07:26 PM
RapidRobert
sounds like the only parts change that could be affecting this is a wilder cam & possibly how the untweeked carb is reacting to the lower vac/less stable idle. as said a vac leak is possible. can you set the initial at 17.5 (halfway between the 15 & 20 on the tab) & see if you can get a reasonably stable idle (as slow as you can get) & what idle speed & what the timing marks are doing. what springs are in the dist (OE light/heavy with elongated loop on one end?)
Re: 383 Timing woes
[Re: Paul G]
#2123603
08/02/16 07:29 PM
08/02/16 07:29 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
car went through a complete resto. Engine was apart when I bought it. Block was hot tanked and rebuilt to factory specs except for mild head work, 0.030" over, Cam is a Mopar Purple shaft 284/284, 0.484/0.484". Stock Holley carb (600cfm?)and stock intake. Distributor is factory that came with the car I disassembled/cleaned it up installed new points and condenser, cap and rotor. Coil is a OEM factory unit. Using new reproduction wires...... Original factory distributor with 1971 electric retard timing box along side vacuum advance diaphragm ??? If this is the case
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: 383 Timing woes
[Re: Paul G]
#2123668
08/02/16 09:25 PM
08/02/16 09:25 PM
bee1971
Sobieski Wi
I run the original 284/484 purple cam in my numbers matching 383 magnum
Idles perfectly at 700 rpm s all day long , starts and runs cold at idle even without a choke plate in my factory carter avs carb
16 degrees initial at idle
20 degrees mechanical advance all in by 2400 rpms
I replaced the slotted t bar within the distributor , taken out of a slant six to shorten the slots for mechanical advance
36 degrees total - No vacuum advance hooked up even though it looks hooked up at carb
Re: 383 Timing woes
[Re: Paul G]
#2123672
08/02/16 09:32 PM
08/02/16 09:32 PM
bee1971
Sobieski Wi
And if he is running the factory original 1971 383 magnum distributor with factory electric retard timing box on side of distributor like I mentioned earlier , pretty good chance from all the ones I pulled and ended up replacing , that's your problem
Convert it to Mopar electronic ignition
Or find a points distributor without the 1971 electric retard timing
Re: 383 Timing woes
[Re: Mr.Yuck]
#2124157
08/03/16 05:09 PM
08/03/16 05:09 PM
Posts: 502 St Louis, Missouri
Runnin74
St Louis, Missouri
your balancer could be seperated. I'd check the balancer as Mr. Yuck suggests just to be sure. I had a jeep that separated the balancer and could never time it correctly except by ear. If I used the numbers then it ran like a turd and if I went back and checked it 2 hours later it would be slightly different. Then one day I shut it and my ears hear an old school telephone ring coming from under the hood???? The balancer had come completely loose and the outer rim of the balancer would continue to turn on the inner ring after the motor was shut off (making the ringing noise). Finally all those symptoms made sense.
Re: 383 Timing woes
[Re: Paul G]
#2125459
08/05/16 02:56 AM
08/05/16 02:56 AM
RapidRobert
cant recall what mine looks like but it would have a wire to it & is differently shaped than a regular vac can is
