Re: thermoquad Carburetor Solenoid Wiring Harness
[Re: joelson6]
#2121176
07/30/16 11:01 AM
07/30/16 11:01 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
wow, i can't believe no one on here has a TQ with A/C. you forgot the last part "that needs a wire harness to hook it up" Why don't you just make one yourself?
[Re: joelson6]
#2121695
07/31/16 01:55 AM
07/31/16 01:55 AM
Posts: 2,918 Calgary, Alberta Canada
a12rag
Do you have the factory service manual to see how the factory wired it in?? I have the idle solenoid on my 74 Duster360 with TQ, and it is wired to the hot field wire on the alternator - but that means the minute you turn the key on, the solenoid pops out to keep the idle speed higher. I would think that for A/C, you would wire it to the compressor circuit, so the minute the compressor is turned on, then the solenoid is popped out and higher idle speed. I am going to add this to my 70 Sport Satellite with A/C, so the idle will pick up when the A/C is on . . .
Cheers
[Re: joelson6]
#2122116
07/31/16 07:31 PM
07/31/16 07:31 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
oh, can't find anything in the service manual about it either, other than how it works. I checked a '72 parts catalog also, no dice. From the factory it attaches to the one of the field terminals on the alternator. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: joelson6]
#2122176
07/31/16 09:28 PM
07/31/16 09:28 PM
3hundred
Colleyville
alright, i checked my shop manual again and yea, it's there, your pic is for a dart, but the challenger diagram has it too. then i have this solenoid all wrong, it's not for the A/C and it's suppose to have power all the time. i'm even more confused now of the actual purpose of it. Anti Dieseling I believe. Were I you I'd hook up a relay to the A/C circuit so it works as you like. Robert
