Dang it, I broke it. COMPRESSION CHECK 08/07
#2121870
07/31/16 01:04 PM
07/31/16 01:04 PM
Posts: 16,813 Between Houston & Galveston TX
SattyNoCar
I admittedly drive my Dakota with a heavy foot, but, never literally foot to the floor screaming high RPM's.... In a moment of frustration/panic, I wound the engine pretty tight last week. Now it smokes every time I start it. Too little time and too hot outside to dig in and diagnose it right now. Aside from the smoky starts, truck feels no different. But, it is using oil now. I'm thinking of buying a long block for it, but, with 166K on everything else, what kind of can of worms would I be opening? Truck is rust free (not dent free though) and aside from the AC not working, has been a good little truck in the year and a half I've owned it. Truck has the V6 and I would probably keep it. Just thinking out loud here. What would you do?
John
Re: Dang it, I broke it. Do I fix or move on.......
[Re: SattyNoCar]
#2121940
07/31/16 02:41 PM
07/31/16 02:41 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I would keep it and build a fresh V6 for it. The truck does not owe you anything and whatever you get to replace it will have its own host of gremlins to be sorted.
I have thought several times that I should be selling my '87 and get a newer truck. I have seen a lot of appealing Dodges on CL and they would be perfect for towing a car trailer with the Ramcharger. But I don't need it yet and I also don't have payments either. The '87 runs very well, gas is cheap now, I have a new canopy on it and my dogs are comfortable and secure in it.
BTW 166K is not a lot of miles for a truck.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: buildanother]
#2121945
07/31/16 02:47 PM
07/31/16 02:47 PM
SattyNoCar
Lower pan on intake been done on it yet? One of the first things I did. I used the Hughes kit. No A/C in this hasn't been too bad. My wagon has no A/C and that was BRUTAL!
John
[Re: SattyNoCar]
#2121956
07/31/16 03:04 PM
07/31/16 03:04 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Time to swap in a 318 or 360. More power and no worse on fuel. Go to to the salvage yard and find a low mile motor and stick it in there.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2122009
07/31/16 04:42 PM
07/31/16 04:42 PM
SattyNoCar
Time to swap in a 318 or 360. More power and no worse on fuel. Go to to the salvage yard and find a low mile motor and stick it in there. If I go with the V8, do I need to swap the trans too? Then there's the matter of wiring and computer. I looked underhood one day and thought "Hmmmm... a modern Hemi would fit".....but reality is that would be WAY beyond my budget. Or would it?
John
[Re: SattyNoCar]
#2122052
07/31/16 05:58 PM
07/31/16 05:58 PM
71yelladustr
Missouri U.S.A.
The trans will bolt right up to a v-8. The motor mounts, accessories and exhaust bolt on. You will need a v-8 PCM and possibly a harness. I was cheap and used the existing V-6 harness when I did mine. Just had to add 2 injector driver wires to make it work.
[Re: 71yelladustr]
#2122242
07/31/16 11:08 PM
07/31/16 11:08 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Time to swap in a 318 or 360. More power and no worse on fuel. Go to to the salvage yard and find a low mile motor and stick it in there. He's right. There's lots around, they are dirt cheap and the miles are low. Not only that, but I think you will get your money back at re-sale time: you'll have the only 360 Dakota in the classifieds and people will want it!
Mo' Farts
Moderated by "tbagger".
[Re: SattyNoCar]
#2122282
07/31/16 11:52 PM
07/31/16 11:52 PM
Posts: 6,003 Salem
Grizzly
Salem
I think you're okay. If the weakest one you have is the 904 based one (42 or 44RH/RE) it should'nt be an issue. Actually, better than the 727 based power-sucking turds (46RE/RH).
Mo' Farts
[Re: SattyNoCar]
#2122916
08/01/16 09:35 PM
08/01/16 09:35 PM
Posts: 10,551 Freeport IL USA
poorboy
Freeport IL USA
I guess the question is, how much oil is it going through? That would be the deciding factor. Might be a good time to run a compression test to see if you broke rings or piston ring lands. If the compression test shows OK, you probably blew out the valve seals or the bottom intake gasket.
I over revved the 3.9 in my coupe when I was out playing one day. Even after that, it ran nearly a full year before I grew concerned enough I replaced it. That motor had a pretty sorted history to begin with, and 149K miles on it. I replaced it with another 3.9 (I bought a wrecked truck with a good motor for cheap). That replacement used motor uses a quart of oil about every 1,000 miles when driving around town (even nearly dead, the original motor didn't use oil). The "new" motor has 118K miles and has had a timing belt replaced.
The truck I bought (for then scrap price, $275) has nearly paid for itself from parts I've sold off, I'm keeping it around in case I need something else, too bad the frame was bent so badly.
Even with a nearly free replacement motor, I have $300-$400 in stuff I've replaced with the motor (the while I'm here syndrome).
I'd run your current motor until it shows signs that concern you. That may be a very long time. A running driving Dakota (of that era) that moves down the road (even with a smoking motor) will bring $1,000 here, parts trucks still bring $500. Run it until it dies, then sell it to someone building an old car or truck. Gene
[Re: poorboy]
#2123065
08/02/16 12:09 AM
08/02/16 12:09 AM
SattyNoCar
I don't see a lot of smoke, but,admittedly its hard to watch the tailpipe all the time. Usually it uses about half a quart between oil changes (3500-4000 miles), its gone down half a quart in about 200 miles since this happened. And today I (briefly) heard what sounded like piston slap? Not 100% sure, but, it was definitely a sound I haven't heard before. Prices on Dakotas around here vary widely (by huge margins), no rhyme or reason. It's VERY rare to see one below $800 no matter how trashed it is. I almost scored another '93 for cheap last year, but the owner wouldn't budge on the price. The truck ran good but had a blown trans, they were asking $650, I had $500 cash and honestly couldn't go higher at the time. They junked the truck instead. I guess Pick-A-Part gave them more than I could.
[Re: 440_Offroader]
#2123801
08/03/16 01:13 AM
08/03/16 01:13 AM
Polarapete
Graham, WA
My powerwagon was exactly like that... big puff of smoke on start up. Pull the valve covers and see if the seals are even there. Some valve seals and valve cover gaskets are cheap. I'd go with poorboys suggestion with a compression test first, just to make sure the cylinders are good. That is the first thing you should do (1) Compression test - dry (2) Compression test - wet (2 squirts of oil in each cylinder before testing) this will determine good rings or bad, if no change and still big variation in numbers then you have a valve sealing issue. Testing is cheap and will prove a lot.
[Re: Rhinodart]
#2124182
08/03/16 06:05 PM
08/03/16 06:05 PM
poorboy
Freeport IL USA
I'd say you shatter a ring or two, when I did that it started using oil and smoked... Yea, I did that in my younger days. Bought a nice big block car from a little old lady, then my young butt started hot rodding it. In very short order it started smoking. My boss informed me that a ridge forms at the top of the cylinder above the top ring travel. When you dramatically increase engine rpm over what it usually ran, the rings travel up the cylinder walls a couple thousands and the rings hit that ridge and break the rings, or the pistons around the rings. OOPS! The more something costs you, the better you remember the lesson. Gene
[Re: poorboy]
#2125324
08/04/16 11:36 PM
08/04/16 11:36 PM
SattyNoCar
I won't be able to diagnose it until this weekend, but, I noticed something different today..... The PCV valve doesn't buzz anymore. Back in April I posted here asking why it would buzz, most people felt it was 'normal'. Pulled the PCV valve out tonite, its not full of oil, and still has strong vacuum. Saturday can't get here soon enough......
[Re: SattyNoCar]
#2125399
08/05/16 01:09 AM
08/05/16 01:09 AM
71yelladustr
Missouri U.S.A.
How much blowby does it have with the PCV valve pulled?
[Re: 71yelladustr]
#2127077
08/07/16 12:44 PM
08/07/16 12:44 PM
SattyNoCar
OK, here we go. My gauge reads in 5 lbs increments, so slight differences are hard to put an exact number to. Cyl 1: 160 Cyl 3: 155 Cyl 5: 155 Cyl 2: 160 Cyl 4: 165 (checked this one twice dry, same reading) Cyl 6: 155 A squirt of oil had minimal affect. Here's a pic of the plugs: Nothing looks 'wrong'. One thing I did notice is I smelled gas quite a bit on the plugs, even though the truck had been sitting for about 10 hrs without being started. Same thing when I was doing the tests, I could smell gas. I had the fuel pump relay unplugged, the coil (power) wire unplugged, and the throttle body held open during the tests. It smelled enough that my wife asked if I had spilled gas. Smelling the oil, it just smelled 'used', no strong gas smell. I'm leaning towards it being the valve stem seal(s), but, the fuel smell has me concerned. Ideas?
[Re: SattyNoCar]
#2127087
08/07/16 01:06 PM
08/07/16 01:06 PM
Posts: 4,254 Canada
WO23Coronet
Canada
Those are good numbers and nice looking plugs. Have you looked into the intake to see if there's oil in the bottom of the plenum? Also see how much vacum it pulls at idle, a blown plenum gasket should show low vacum
[Re: WO23Coronet]
#2127185
08/07/16 03:49 PM
08/07/16 03:49 PM
SattyNoCar
I couldn't find my vacuum gauge, so I have no readings. I just have this unscientific video.... PCV vacuum Oh, and the 'buzz' from the PCV returned yesterday. One more video showing the V6 at idle... idling V6 zzzzzz Like I said previously, it runs no different. It just smokes at first fire and uses oil now.
[Re: SattyNoCar]
#2127623
08/08/16 01:33 AM
08/08/16 01:33 AM
poorboy
Freeport IL USA
It takes a lot of extra oil usage to add up to the cost of most repairs. Think maybe I would give it a fresh oil & filter change, and track exactly how much oil it is actually using. Back in the old days, Chrysler said a quart in 500 miles was acceptable, even in a new motor! From my perspective, a quart in 1,000 miles is borderline excessive.
When you have to add oil between gas fill ups, I believe the oil consumption has exceeded excessive, and its time to do something.
Most of my higher mileage Mopar motors have given a puff of smoke when they start. At least I know they are getting upper cylinder lubrication. Gene
[Re: SattyNoCar]
#2127770
08/08/16 12:03 PM
08/08/16 12:03 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
Sounds exactly like valve stem seals. Probably not to hard of a job to do this fall or winter.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2128263
08/08/16 10:55 PM
08/08/16 10:55 PM
SattyNoCar
Oil consumption..... It's definitely using more at freeway speeds. Took the truck down to West Beach (Galveston) yesterday. Checked the oil before leaving, dead on the fill line. I drove approx. 90 miles round trip, 30 of which were slower 'in town' speeds. Checked oil a few hrs after I got home, it was down to the add line. Yes, I've had a few cars that burned WAY more oil, but, to go to this much use from less than half a qt in 3500+ miles is a bit of a . On a side note, I didn't have a full tank of gas so I couldn't calculate the MPG, but, the truck used about a 1/4 tank to cover those 90 miles.
[Re: SattyNoCar]
#2128883
08/09/16 07:37 PM
08/09/16 07:37 PM
poorboy
Freeport IL USA
With the compression numbers you have, I think I would be looking at an intake gasket failure, either the bottom gasket, or the actual intake gaskets. Its got to be pulling oil into the combustion process, the compression numbers you have means its probably not coming by the rings, and that is a lot of oil coming through the valve guides, even if the seals are nearly gone. Two other possibilities come to mind. 1) Somehow the oil returns to the pan got partly plugged up and the oil is sitting up in the valve covers. 2) Oil is running out on the ground from someplace, Oil sending unit maybe? Gene
[Re: poorboy]
#2128984
08/09/16 10:12 PM
08/09/16 10:12 PM
SattyNoCar
I don't hear any pinging at hwy speed, or any speed for that matter.... There's no puddles under the truck or on the engine. It just looks like a typical high mileage piece, no excessive oil on the engine anywhere. I'm just gonna stick close to home with it until this heat breaks and I can dig into it. Thanks everyone.
Re: Dang it, I broke it....... Frustrated/Confused Oct 1st
[Re: SattyNoCar]
#2166227
10/02/16 12:41 AM
10/02/16 12:41 AM
SattyNoCar
Its been ...two months since I thought I broke my Dakota. The summer heat finally ended, but now life (re:work) keeps getting in the way, so I've done nothing to it except drive it. Where I'm frustrated/confused is that once the extreme summer temps quit, oil consumption went way down, and now that more fall like temps have finally arrived, oil consumption is back to what it was originally. I really like this little truck, but, my lack of time (and knowledge) to diagnose all its little quirks, may push me in a direction I didn't want to go. One other quirk that seems temp related is an occasional dead miss at idle (sitting at a light with my foot on the brake). Only happens when its HOT out. Lean miss? And as of late, I've noticed it runs so much better/stronger, when its 80 or cooler out and it has half a tank (or less) of gas. Hard to explain, but, its not a weight difference thing. Don't laugh at my example, but, when its really hot out, the truck will just kinda mosey up to speed if you gun it. Half a tank and temps 80 or less, the in dash cup holder will slide open, and it'll chirp second. I know its not uncommon for cars to run better in cooler temps, but, this seems a bit extreme, especially for a computer controlled one. Like I've said, I'm just frustrated right now.
John
