Re: Organosol "The Bulletin" January 15, 1969
[Re: RoadRunnerJD]
#21216
12/18/05 01:57 AM
12/18/05 01:57 AM
Posts: 21,505 N.E. OHIO, USA
A12
N.E. OHIO, USA
Your library of info is amazing! Do you think this is how the hood is done? I know that my hood is too gritty the way it is now and I'm kind of leaning toward the way it looks in the current special Hot Rod which is way smoother.
John, someone that I respect quite a lot with Mopar restoration told me to look for paint code 9407 that this may be the "missing link" for the A12 and AAR/T/A hood paint. I asked if anyone here knew what 9407 was but as of now no reply.
I have this (see attachment) and the Dupont, R-M, and PPG paint chips but there is nothing on 9407 or any black except the 88L and Organosol.
MikeR
[Re: RoadRunnerJD]
#21220
12/19/05 02:52 PM
12/19/05 02:52 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
I wonder if it's a PPG number? I have been using PPG Duracryl #9355 but it's just too gritty.
That is what I have found to be the best solution to this Organisol paint situation. I painted 4 different 6bbl hoods over the years all with trying different thinner levels, temperature , air pressure etc. Always too much grit.
I shot PPG 9355 and used the slowest reducer. I was able to make a normal pass, followed by a pass going across what I just shot. It goes on like primer looking like it will be rough, but it flows out and lays down really nice with the slow reducer. I let it flash and then two more passes, criscrossing. Here is a picture of the results. Not an A12 hood but it is on a plastic bubble and a fiberglass hood scoop. I loved the way it cooperated and turned out. It matches the finish on an original A12 hood dead on.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: Fasbird]
#21222
12/19/05 06:24 PM
12/19/05 06:24 PM
Posts: 1,355 maine
LO23
maine
[Re: QuickSilver]
#21224
12/19/05 07:10 PM
12/19/05 07:10 PM
A12
N.E. OHIO, USA
Are you sure the PPG number isn't 9437? I have some of this and it is labled 9437 organisol in which I used to restore the tail light panel on a 69 R/T Charger and it turned out perfect. Man did it dry down very nice. I can't wait to spray my hood. Not to gritty at all and just the look I want for mine!
Quicksilver, maybe it is 9437? I have to call. (Does this 9437 have a name?)
MikeR
[Re: Fasbird]
#21225
12/19/05 11:30 PM
12/19/05 11:30 PM
MOPARMIKE69
Nashville, TN
The original PPG number was DDL 9355, the "L" means laquer. Most paint suppliers do not mix laquer anymore. They can pull up the 9355 formula in the computer and mix it as an enamel. It works much better than the laquer. That is why you can use the slower reducer. The code is correct. After using this I would never shoot the laquer Or"crap"asol again. Same correct formula just enamel. Organasol works well on small panels etc. but when you try to spray it on large areas it goes on too dry, therefore it gets rough. It leaves uneven stripes because of the over spray from the gun on a large area.
[Re: MOPARMIKE69]
#21226
12/20/05 01:53 AM
12/20/05 01:53 AM
Posts: 4,912 The Dark Side
Fasbird
The Dark Side
That's why I asked the above question. Laquer and reducer don't mix well.
[Re: QuickSilver]
#21228
12/20/05 07:54 PM
12/20/05 07:54 PM
Posts: 1,355 maine
LO23
maine
you can also get "organosol black" 9355 mixed in dcc low gloss "concept" ppg also. lead free formula special low gloss color mix:6 pts paint;2 pts dt reducer;1 pt dcx61
[Re: Danan]
#21231
01/06/06 12:37 AM
01/06/06 12:37 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
The stuff I got says 9346 on the can went on real easy and looks good seems to have the right texture also.Used it on my AAR
[Re: ns1aar]
#21232
01/09/06 04:53 PM
01/09/06 04:53 PM
i also need to get the Organisol for my tail light panel for my 69 Charger. Has anyone used the Organisol paint from Totally Auto? Is it any good or close to what the original stuff was?
thanks,
Brian
