Re: Stock (4 lights) headlight upgrades using relays
[Re: shipfitter_sjd]
#2121162
07/30/16 10:29 AM
07/30/16 10:29 AM
Posts: 543 Indiana, Just Off I-70
BradD
You could probably use the high and low wires as relay trigger wires. Run the power from the battery through a 20amp fuse to the lamps. All work done at front of the car near the lamps. I did a 69 Barracuda for a customer, but we replaced the intire harness with an EZ brand harness. And that was about 4 years ago so my memory has faded. Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
#2121171
07/30/16 10:51 AM
07/30/16 10:51 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
routing power from the battery right to the headlights. Worse place you could choose as the power source. Tap off the alternator output stud.
#2121207
07/30/16 12:02 PM
07/30/16 12:02 PM
Posts: 12,058 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
This is a great upgrade. For less than $20 you get brighter headlights and protect your wiring harness and switch. I have done this a dozen times or more. https://www.youtube.com/watch?v=Tw9QkkT2ptUhttp://www.lindamaki.com/wp-content/uplo...ing-diagram.bmpThe relays are available at all auto parts stores. Use the one that is pictured in the video above because it has the mounting tab made on it. You do not use the middle spade, only the 4 outside ones. The starter relay is the power source that I use due to it's convenient location. There are other videos on UTube if you need more reference material. And I think there are other threads here on Moparts on this subject with even more info. If you have anymore questions, just ask.
Master, again and still
[Re: Supercuda]
#2121239
07/30/16 12:40 PM
07/30/16 12:40 PM
RapidRobert
Tap off the alternator output stud. Agreed, feeds em right from the (power) source/increases brightness from less voltage drop (which is your intended purpose)/takes load off of the bulkhead/keeps the ammeter honest. as said trigger em with the hi/lo beam wires
