Wow... Time for 5/8“ wheel studs?!
#2121136
07/30/16 09:24 AM
07/30/16 09:24 AM
Posts: 3,638 Oakland, MI
dizuster
Oakland, MI
Went to take off my wheels yesterday to mount up some new tires. Couldn't believe my eyes! Checked all of the lugs and they were all at least 100 ft/lbs to remove, so they weren't loose! These where strange screw in studs running with a steet wheel. Drag radials, Trans brake, 3740lbs, 1.38 best 60ft.
Re: Wow... Time for 5/8“ wheel studs?!
[Re: dizuster]
#2121138
07/30/16 09:30 AM
07/30/16 09:30 AM
Posts: 2,981 A shed in England
Tig
A shed in England
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: dizuster]
#2121148
07/30/16 10:06 AM
07/30/16 10:06 AM
Posts: 619 nj
JAMESDART
nj
[Re: dizuster]
#2121151
07/30/16 10:11 AM
07/30/16 10:11 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
And/or put that thing on a diet! haha Good catch!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: dizuster]
#2121158
07/30/16 10:18 AM
07/30/16 10:18 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Check the housing for straightness, good chance it's bent also.
Have a great day Iowan
"obsolete is neat"
[Re: Iowan]
#2121161
07/30/16 10:25 AM
07/30/16 10:25 AM
Posts: 3,401 Pa
Hot 340
Pa
Do i see the pic right? It looks like the holes in the flanges are bigger than the studs going through them. If so, that wouldnt provide the stud with any side support.
Edit...i see its a disc brake rotor on there.
[Re: dizuster]
#2121165
07/30/16 10:33 AM
07/30/16 10:33 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I was shearing 1/2" studs in my "Cuda before I switched over to 5/8" drive studs. Never hurt a wheel again. It is a little work, though. Axles have to be drilled and tapped. Holes in brake rotors will have to be opened up. And it will be a pretty snug fit with the wheels, too. It will be a straight shot in, so you will have to be able to maneuver the wheel around in the wheel well for that.
[image][/image]
[Re: dizuster]
#2121187
07/30/16 11:26 AM
07/30/16 11:26 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Where are you gonna find steel wheels for 5/8 studs? I remember Monte saying drag radial cars need to be built like a promod in the rear.
[Re: 340Cuda]
#2121233
07/30/16 12:34 PM
07/30/16 12:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Happens a lot on steel wheels... the surface area at the base of the stud isnt big enough.. with all the torque they will move.. and pounds on the edges of the base.. once its large enough it can do anything.. but see where the studs are cut down .. thats at the base area
[Re: 340Cuda]
#2121259
07/30/16 01:07 PM
07/30/16 01:07 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Maybe it's just the photo but the center hole in your wheel appeared to be larger than the register on the axle. If this is the case I can see how this would be hard on the studs.
Good luck with it all, Bill I agree, that register hole in the wheel doesn't match the axel register. That, didn't help at all. Probably the main cause. Second all the power at the hit, that your putting down.
[Re: dizuster]
#2121289
07/30/16 02:03 PM
07/30/16 02:03 PM
Thumperdart
State of confusion
Ya man, you be needin the big dawgs now w/that beast of yours..........
[Re: dizuster]
#2121290
07/30/16 02:06 PM
07/30/16 02:06 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
No...........the problem is drag radials. They are unforgiving and break EVERYTHING. And I would also bet the housing is bent from the spring perches out.
The issue with steel wheels and ANY size stud in something with power, is the way the wheel mounts. When aftermarket parts are involved, the wheel no longer registers on the axle. The hole in the wheel is bigger than stud and your sole means of support is the cone on the nut. Add drag radials and I am surprised it hasn't already broke the studs. So even if you do go 5/8 studs, you are going to have to come up with another way to clamp a steel wheel, if that is what you are going to run. The wheel MUST fit the unthreaded shank on the stud, as that is what supports the wheel
[Re: Monte_Smith]
#2121294
07/30/16 02:10 PM
07/30/16 02:10 PM
Posts: 4,804 Wichita
GY3
Wichita
No...........the problem is drag radials. They are unforgiving and break EVERYTHING. And I would also bet the housing is bent from the spring perches out Mine snapped an ear off a Spicer 7290 u-joint 2 weeks ago running ET Street Pro's. I was surprised it happened at my power level! Of course it was trashing the Auburn sure-grip as well but I expected that.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: Monte_Smith]
#2121334
07/30/16 03:04 PM
07/30/16 03:04 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
The issue with steel wheels and ANY size stud in something with power, is the way the wheel mounts. When aftermarket parts are involved, the wheel no longer registers on the axle. The hole in the wheel is bigger than stud and your sole means of support is the cone on the nut. Add drag radials and I am surprised it hasn't already broke the studs. So even if you do go 5/8 studs, you are going to have to come up with another way to clamp a steel wheel, if that is what you are going to run. The wheel MUST fit the unthreaded shank on the stud, as that is what supports the wheel What Monte said but I will add that the vee shape hole in the steel wheel is like a cleaver to the stud. It may be possible to get straight shank studs and open up the holes in the wheels to the straight size diameter, or maybe some hat inserts like Lamb sells for the front wheels. There is a yellow TT Nova here that sheared off the studs launching on a well prepped track (Raidalfest at Huntsville) two events in a row. He put new studs on this year after shearing them off last year, and the results were the same except this year he went into the wall. Steel wheels on threaded studs + traction + power = trouble. Yeah, you dodged a bullet. Go buy a lotto ticket.
