wheelie guys,what do you use for travel limiters #212104
02/02/09 05:13 PM
02/02/09 05:13 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I'm on a never ending quest to remove unneccesary weight with out spending any money. The factory up and down bump stop brackets look like at least 4-5 lbs. I can use a cable for a upper A-Arm limiter. The lower is another story. I could move the stop inward on the lower arm so it contacts the rail. Though it might have to be sunk into the middle of the arm towards the pivot. Or maybe it doesn't even need one. I doubt if the aftermaket front susupensions have them or a tube car. The car may be a wheelstander. How about it what do you guys use? The car should be aprox 3300lbs w/driver,10.5W tire,ladder bar. Hping to go low 9. I would think once the suspension is dialed it should leave pretty smooth. 20 things that weigh 5lbs is 100lbs
Doug
Re: front suspention travel limiters [Re: dvw] #212105
02/02/09 05:18 PM
02/02/09 05:18 PM
we just have a bolt that is adjustable.... works good
Casey
Re: front suspention travel limiters #212106
02/02/09 05:28 PM
02/02/09 05:28 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I have no problem using a bolt. But what I want to eliminate is the bulky bracket welded to the frame rail.
Doug
Re: front suspention travel limiters [Re: dvw] #212107
02/02/09 05:37 PM
02/02/09 05:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
You would be better off using that bracket for the
bolt stop(you might be able to trim it down )
Re: front suspention travel limiters [Re: MR_P_BODY] #212108
02/02/09 05:42 PM
02/02/09 05:42 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
How about the lower arm stop? Do I need it? I wonder how effective it is on cushioning a wheel stand.
Doug
Re: front suspention travel limiters [Re: dvw] #212109
02/02/09 06:31 PM
02/02/09 06:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
I would prefer to have something there to absorb
some of the shock and not just steel to steel,
but I dont run a stock frontend, my struts have a
rubber cushion on top to pick up the load. Maybe
someone that runs a stock front will chime in
Re: front suspention travel limiters [Re: MR_P_BODY] #212110
02/03/09 12:30 PM
02/03/09 12:30 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Bump for th morning guys
Re: front suspention travel limiters [Re: dvw] #212111
02/03/09 01:33 PM
02/03/09 01:33 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
I would leave the lower stop in place. I use a rounded carrige bolt through the factory upper snubber hole.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: front suspention travel limiters [Re: HemiDart68] #212112
02/03/09 01:41 PM
02/03/09 01:41 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
I agree with leaving the lowers and the uppers if you dont want it to come up.A pair of Afco's will also slow the front end.
Re: front suspention travel limiters [Re: cudabunch] #212113
02/03/09 02:49 PM
02/03/09 02:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My Duster uses a spacer (I have a few of different heights) for the upper control arms, with an OEM rubber bumper where the control arm hits the limiter. Normal spec is 1.000 - 1.250 inches. The spacer is aluminum bar stock with a stud threaded into the bottom and a threaded recess for the bumper at the top. IIRC, the top of the bumper is trimmed flat by about 1/2" - to be honest I haven't looked at it in awhile...
Re: front suspention travel limiters [Re: HemiDart68] #212114
02/03/09 06:28 PM
02/03/09 06:28 PM
NC
440Jim Offline
440Jim  Offline
NC
When that wheel stand comes down, you will want something there. All it takes is one excessive wheel stand coming down hard to ruin your day.
Re: front suspention travel limiters [Re: 440Jim] #212115
02/03/09 06:46 PM
02/03/09 06:46 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Thats what I wanted to know. Big wheel stand w/o lower cushions. Are they of any value? Or will it hit hard even with them.
Doug
Re: front suspention travel limiters [Re: cudabunch] #212116
02/03/09 06:49 PM
02/03/09 06:49 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
The AFCO's eliminated any need for travel limiters in my application. I can set it up to pull em 6 inches or hang em 3-4 feet at the twist of a knob. And yes it really is that easy.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: front suspention travel limiters [Re: Irun5snd8th] #212117
02/03/09 07:21 PM
02/03/09 07:21 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
You got that right
Re: front suspention travel limiters [Re: Irun5snd8th] #212118
02/03/09 07:29 PM
02/03/09 07:29 PM
Connecticut
5126brl No more Offline
Connecticut
ball park price for a pair for a 69 b-body?
do they fit stock chassis mounts? thanks
Re: front suspention travel limiters #212119
02/03/09 07:39 PM
02/03/09 07:39 PM
Bakersfield, CA
Jared_Jordan Offline
Bakersfield, CA
Casey
That's all I use. 1.18 60 ft @ 3420 lbs.
Re: front suspention travel limiters [Re: Jared_Jordan] #212120
02/04/09 12:04 AM
02/04/09 12:04 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
It needs the lower rubber stops. Hit one with a hammer, you'll feel that it's worth while...
