wheelie guys,what do you use for travel limiters
#212104
02/02/09 05:13 PM
02/02/09 05:13 PM
Posts: 9,826 MI, usa
dvw
MI, usa
I'm on a never ending quest to remove unneccesary weight with out spending any money. The factory up and down bump stop brackets look like at least 4-5 lbs. I can use a cable for a upper A-Arm limiter. The lower is another story. I could move the stop inward on the lower arm so it contacts the rail. Though it might have to be sunk into the middle of the arm towards the pivot. Or maybe it doesn't even need one. I doubt if the aftermaket front susupensions have them or a tube car. The car may be a wheelstander. How about it what do you guys use? The car should be aprox 3300lbs w/driver,10.5W tire,ladder bar. Hping to go low 9. I would think once the suspension is dialed it should leave pretty smooth. 20 things that weigh 5lbs is 100lbs Doug
Re: front suspention travel limiters
[Re: dvw]
#212105
02/02/09 05:18 PM
02/02/09 05:18 PM
we just have a bolt that is adjustable.... works good
Casey
[Re: dvw]
#212107
02/02/09 05:37 PM
02/02/09 05:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have no problem using a bolt. But what I want to eliminate is the bulky bracket welded to the frame rail. Doug
You would be better off using that bracket for the bolt stop(you might be able to trim it down )
[Re: dvw]
#212109
02/02/09 06:31 PM
02/02/09 06:31 PM
MR_P_BODY
How about the lower arm stop? Do I need it? I wonder how effective it is on cushioning a wheel stand. Doug
I would prefer to have something there to absorb some of the shock and not just steel to steel, but I dont run a stock frontend, my struts have a rubber cushion on top to pick up the load. Maybe someone that runs a stock front will chime in
[Re: MR_P_BODY]
#212110
02/03/09 12:30 PM
02/03/09 12:30 PM
dvw
MI, usa
[Re: dvw]
#212111
02/03/09 01:33 PM
02/03/09 01:33 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
I would leave the lower stop in place. I use a rounded carrige bolt through the factory upper snubber hole.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: HemiDart68]
#212112
02/03/09 01:41 PM
02/03/09 01:41 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
I agree with leaving the lowers and the uppers if you dont want it to come up.A pair of Afco's will also slow the front end.
[Re: HemiDart68]
#212114
02/03/09 06:28 PM
02/03/09 06:28 PM
Posts: 16,923 NC
440Jim
NC
When that wheel stand comes down, you will want something there. All it takes is one excessive wheel stand coming down hard to ruin your day.
[Re: Irun5snd8th]
#212117
02/03/09 07:21 PM
02/03/09 07:21 PM
cudabunch
Wellington, FL
The AFCO's eliminated any need for travel limiters in my application. I can set it up to pull em 6 inches or hang em 3-4 feet at the twist of a knob. And yes it really is that easy.
You got that right
#212119
02/03/09 07:39 PM
02/03/09 07:39 PM
Posts: 144 Bakersfield, CA
Jared_Jordan
Bakersfield, CA
Casey
That's all I use. 1.18 60 ft @ 3420 lbs.
