I just changed over to a solid FT cam from Hughes... the
2 choices they had for the FT was standard and light weight
and if it had the EDM hole on the face.. I went with the
light weight with the EDM hole.. their EDM hole is .012..
much smaller than the Comp solid roller.. .026.. on the roller
my oil pressure showed low and I base a lot of that on the .026
hole X 16... plus I PR hole so thats another built in leak but
I'm using paired TD rockers so PR oiling was basically my only
choice.. I plugged off the head oiling.... but all this was info
is for a solid FT so I cant help with the Hughes rollers.. but
I would be on the phone and ask and also ask about their EDM
oil hole if its .012 on them also
