electric fuel pump #212039
02/02/09 05:04 PM
02/02/09 05:04 PM
btomasko Offline OP
btomasko  Offline OP
had installed an carter electric fuel pump, to noisy, disconnected it, use regular fuel pump on engine. ran line from tank to in side of disconnected electrical fuel pump and the other line to pump on engine from other side of disconnected electric fuel pump. What problems if any would be going to happen? possible vapor lock? thanks 1968 rr
Re: electric fuel pump [Re: btomasko] #212040
02/02/09 05:07 PM
02/02/09 05:07 PM
MNobody Offline
MNobody  Offline
I would have to wonder if going through the unused electric pump might restrict fuel flow.
Re: electric fuel pump [Re: MNobody] #212041
02/02/09 05:29 PM
02/02/09 05:29 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I wonder why you would even bother. If you ain't gonna use it, take it out, or at least bypass it.
Re: electric fuel pump [Re: btomasko] #212042
02/02/09 05:34 PM
02/02/09 05:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd remove it all. If you have the can style filter you WILL suck it dry and then your engine will bog until it fills again. FWIW nobody needs an electric fuel pump on a carb'd car unless you are running low 11's. A mech pump is fine.
Re: electric fuel pump [Re: Mr.Yuck] #212043
02/02/09 06:29 PM
02/02/09 06:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Not with the fuel around here, especially the middle of summer. THe gas boils super easy around here.
Re: electric fuel pump [Re: buildanother] #212044
02/02/09 09:33 PM
02/02/09 09:33 PM
btomasko Offline OP
btomasko  Offline OP
BTT
Re: electric fuel pump [Re: buildanother] #212045
02/02/09 10:26 PM
02/02/09 10:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
never ever have had issues w/ gas boiling. You must have your fuel line too close to the block. It gets upper 90's 100 here in the summer. And we have traffic. My trick is I always bend the line from the pump to the carb at least 1/2" form the block and even futher above the intake/heads. You also should always use a carb spacer. a 4 hole 1/2 inch works wonders.
