Re: DIY alignment tools? recommendations?
[Re: 451Mopar]
#2120175
07/28/16 09:54 PM
07/28/16 09:54 PM
RapidRobert
I ain't done it at home but I will. there are some good utube videos I believe that will help & one guy said use salt instead of grease. I would get the camber plumb with a 2ft carpenters level vertical on the sidewalls and the toe in straight with a tape with st wheel centered & box halfway between lock to lock and the suspension height where you like the wheel fitment in the wells and drive it for several miles to settle everything then recheck/reset everything with a half tank of gas and your weight in barbells in the dr seat & tires aired up & front wheelwell/tire fitment OK to you and just me I would turn the cams to get max positive caster then bring the rear cam forward as needed till the camber is zero or a skosh neg & let the caster fall where it may & call it good & if the front cam(s) do need to be also turned to get plumb on the camber then that too. EDIT & first you'd wanna string it to get it level & I have some plates from Lowes that I will use when the time comes (stack them under each tire till the 4 sections of string anchored between the top plate and bottom of tire treads are level)
[Re: Andrewh]
#2120262
07/28/16 11:48 PM
07/28/16 11:48 PM
Posts: 27,475 So Cal
autoxcuda
So Cal
I bought the Longacre unit I figured I was getting a cool angle finder that pops out/in with just a magnet.... Haven't used it for anything else yet though.
[Re: RapidRobert]
#2121035
07/30/16 01:06 AM
07/30/16 01:06 AM
Posts: 1,459 oklahoma
forphorty
oklahoma
I ain't done it at home but I will. there are some good utube videos I believe that will help & one guy said use salt instead of grease. I would get the camber plumb with a 2ft carpenters level vertical on the sidewalls and the toe in straight with a tape with st wheel centered & box halfway between lock to lock and the suspension height where you like the wheel fitment in the wells and drive it for several miles to settle everything then recheck/reset everything with a half tank of gas and your weight in barbells in the dr seat & tires aired up & front wheelwell/tire fitment OK to you and just me I would turn the cams to get max positive caster then bring the rear cam forward as needed till the camber is zero or a skosh neg & let the caster fall where it may & call it good & if the front cam(s) do need to be also turned to get plumb on the camber then that too. EDIT & first you'd wanna string it to get it level & I have some plates from Lowes that I will use when the time comes (stack them under each tire till the 4 sections of string anchored between the top plate and bottom of tire treads are level) RR, a carpenters level on the sidewalls won't work well as the sidewall bulges more on the bottom.
[Re: forphorty]
#2121039
07/30/16 01:19 AM
07/30/16 01:19 AM
RapidRobert
RR, a carpenters level on the sidewalls won't work well as the sidewall bulges more on the bottom. Noted!
[Re: thehemikid]
#2121119
07/30/16 07:52 AM
07/30/16 07:52 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Did you use "i align" or is there a free app I didn't see. Yes I did. But I also used an app called "CamberMeas" later on.
[Re: Andrewh]
#2122110
07/31/16 07:16 PM
07/31/16 07:16 PM
Posts: 710 St Louis, MO 63026
convx4
St Louis, MO 63026
I just got this with the magnetic bubble level form e bay. http://www.ebay.com/itm/3D-Wheel-Alignment-Rack-Tool-for-Camber-Caster-Gauge-Adapter-Rim-Clamp-Mount/232031133083?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D37471%26meid%3Dd0bbf08d787444f3ba6aef37ba61b1e4%26pid%3D100011%26rk%3D1%26rkt%3D10%26sd%3D371674228650
[Re: Andrewh]
#2122389
08/01/16 02:24 AM
08/01/16 02:24 AM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
I use a Howe magnetic caster/camber gauge. You remove the grease cap from the spindle, then it sticks to the hub. If you have an aluminum hub, you remove the spindle nut, put a big steel washer on, then tighten the spindle nut back on. THe magnet then sticks to the washer. It is a bubble, and it is acurate and easy to use.
I called a bunch of local garages and asked if they had a set of turntables that weren't using. Scored a pair for dirt cheap. Ugly but they work.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
