97 Dodge 1500 won't accelerate #2119513
07/28/16 12:15 AM
07/28/16 12:15 AM
Saskatchewan, Canada
barracudabob Offline OP
Just bought a 97 Dodge Ram 1500 with a 3.9 auto. It will accelerate to about 30 mph, and no more. Engine is still running, but not speeding up. No codes, and no check engine lites on. Where do i start checking?
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2119552
07/28/16 12:56 AM
07/28/16 12:56 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Disconnect the battery and let it sit for a short while then try it again. It sounds like it's in limp mode. If it's a trans causing it to go into limp it won't give you a code or a light you can read without the trans reader.
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2119892
07/28/16 03:49 PM
07/28/16 03:49 PM
Guitar Jones Offline
A 97 with a 3.9 should have a 42RE trans. Does the transmission shift or just stay in one gear. Does the engine sound like it's laboring or is it revving high?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 97 Dodge 1500 won't accelerate [Re: Guitar Jones] #2120086
07/28/16 07:49 PM
07/28/16 07:49 PM
Trans shifts up and down no problem. The engine just seems to flat spot. push on the accelerator, and nothing, no bucking, backfiring, nothing.
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2120163
07/28/16 09:39 PM
07/28/16 09:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Cat
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2120845
07/29/16 07:29 PM
07/29/16 07:29 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
In 73-75, at a Service station I worked at, we had 4 cars that had the same problem.. All 4 turned out to be collapsed exhaust pipes..
Inner and outer tubing, and the inner had collapsed and blocked the exhaust..
After the 1st one, the rest were a lot easier to diagnose...
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2121011
07/30/16 12:16 AM
07/30/16 12:16 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Check for a restricted catalytic converter
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 97 Dodge 1500 won't accelerate [Re: barracudabob] #2121329
07/30/16 03:00 PM
07/30/16 03:00 PM
I concur, clogged exhaust.
Re: 97 Dodge 1500 won't accelerate [Re: Guitar Jones] #2121660
07/31/16 12:33 AM
07/31/16 12:33 AM
Cleaned the catalytic converter out, and voila, no more problem! Thanks for the advice!
