Roll bar padding
#2119865
07/28/16 03:10 PM
07/28/16 03:10 PM
Posts: 4,206 New York
polyspheric
New York
I spoke to a helmet guy about padding material: inside the bucket, and of course around the tubes where you might hit them in the car. He was surprised that the roll bar and accessory manufacturers do not appear to use (or at least publish) any data on how much load compresses the padding by X amount, and even more surprised that I said use of sponge-appearing material (like water pipe insulation, you can compress it and it expands back) is common, and no definitive way to tell if it's useful at all in an impact; all it will do is prevent tearing injury to the impacted tissue, but almost no effect on reducing the blunt force. Eeekk... If you read about helmet design, the interior only uses sponge-like material for comfort, and as an air seal and wind noise suppressant. The actual padding (protection from crushing and G force) is foam which is very stiff and only works once: if it's been compressed it's used up and at least the foam must be replaced (this presumes that the shell can be tested for integrity, otherwise the whole thing is a wall hangar). Has anyone dented their roll bar padding? Did it stay depressed, or spring back? How much force was applied?
Boffin Emeritus
Re: Roll bar padding
[Re: polyspheric]
#2119880
07/28/16 03:29 PM
07/28/16 03:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
There is 2 different roll bar paddings... one for above 10.0 then the HARD stuff for 9.99 and lower... I have hit my helmet on it but didnt hit hard enough to dent it... the stuff for 10.0 and slower is the foam rap stuff(soft)
[Re: polyspheric]
#2119966
07/28/16 05:35 PM
07/28/16 05:35 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
The soft stuff is absolutely worthless.
I've cracked Bell Helmets racing motocross back in the day, yeah that's a "s", I don't plan on doing at again, but the soft stuff will disappear when it's stuck between your helmet and a hard place.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: polyspheric]
#2119968
07/28/16 05:37 PM
07/28/16 05:37 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
The hard stuff, like I have in my car, doesn't seem like it'd do much on impact.
[Re: an8sec70cuda]
#2119972
07/28/16 05:42 PM
07/28/16 05:42 PM
MR_P_BODY
The hard stuff, like I have in my car, doesn't seem like it'd do much on impact. I have the hard(certed) padding in all my cars... to me it seems like my helmet would just bounce off.. to me that stuff is HARD
[Re: polyspheric]
#2120146
07/28/16 09:19 PM
07/28/16 09:19 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Take a sample of whatever padding suits your fancy, wrap it around a baseball bat. put your helmet on, and have your significant other give a what for on the helmet, and then decide which handles an impact best. I think it will be obvious.
[Re: polyspheric]
#2120155
07/28/16 09:33 PM
07/28/16 09:33 PM
polyspheric
New York
I wish there were a durometer scale or similar for this stuff. The helmet contents look pretty much like beach cooler material (I dropped one down the stairs once and very little happened), but how different is it? Is the stiffer padding split in half (not slit, since it's not flexible) to go around the tube, and fastened with clamps? I'm considering having a 6 point installed in my street-only car, and I would certainly use nothing but the stiff material; unless you're really restrained in a roll-over your scapula, tibia, radius, ulna etc. may strike a tube while flailing around; the bone is at risk. I'm going to see if Snell and TÜV have any info on-line. Any links or references appreciated!
Boffin Emeritus
[Re: polyspheric]
#2120157
07/28/16 09:35 PM
07/28/16 09:35 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am wondering about its flame resistance and toxic smoke if it burns...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
