yes, another hemi carb question ... #21179
12/14/05 01:20 PM
12/14/05 01:20 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
need to see pics of linkage setups using Ebrock or NEW carter carbs on STOCK inline 2-4 bbl intake and how it runs for you .
thanks
Re: yes, another hemi carb question ... [Re: JohnRR] #21180
12/14/05 04:43 PM
12/14/05 04:43 PM
thanks
I don't have any pictures of it, but when I had two new Edel. 750s on my 68 Hemi Charger the factory stock linkage worked just fine.
Re: yes, another hemi carb question ... #21181
12/14/05 04:45 PM
12/14/05 04:45 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
thanks
how did you set it up progressivly ? adaptors readily available , or make shift ?
Re: yes, another hemi carb question ... [Re: JohnRR] #21182
12/14/05 04:56 PM
12/14/05 04:56 PM
thanks
When I bought the 68 hemi Charger it had been a victim of the two Mopar thieving brothers that plegued the northeastern states. They had stolen the very rare Nascar intake that was on the car at the time as well as the original intake and carbs that were in the trunk of the car.
I purchased an original intake and bought new repro linkage from Hemispherical Products and it fit without modification set up as the factory progressive.
Re: yes, another hemi carb question ... #21183
12/14/05 05:27 PM
12/14/05 05:27 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Now boys, quit being civil with each other, that is no way to finish the year!
JB Rhinehart, Realist
A-Body's RULE!
Re: yes, another hemi carb question ... [Re: Rhinodart] #21184
12/14/05 05:38 PM
12/14/05 05:38 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Re: yes, another hemi carb question ... [Re: JohnRR] #21185
12/14/05 05:47 PM
12/14/05 05:47 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Heres a 66 manifold with new Eddies. I set this up as progressive and loved the out come. Sorry don't have a closer pic.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: yes, another hemi carb question ... [Re: moparmarks] #21186
12/14/05 05:50 PM
12/14/05 05:50 PM
moparmarks Offline
moparmarks  Offline
Heres the same Eddie linkage on a 440 setup.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: yes, another hemi carb question ... [Re: JohnRR] #21187
12/14/05 06:01 PM
12/14/05 06:01 PM
I dug around in my 68 Hemi Charger file and came up with these. One of these is a scan of a photocopied pictures so the quality is not real good. In fact, the quality is not real good on any of these. When the came in from my scanner to my photo program they were HUGE and I left them that way as they are a lot easier to read. Be prepared for this when you capture the picture in your photo program.
Re: yes, another hemi carb question ... #21188
12/14/05 06:03 PM
12/14/05 06:03 PM
Re: yes, another hemi carb question ... #21189
12/14/05 06:04 PM
12/14/05 06:04 PM
Re: yes, another hemi carb question ... #21190
12/14/05 06:06 PM
12/14/05 06:06 PM
Re: yes, another hemi carb question ... [Re: Rhinodart] #21191
12/14/05 06:19 PM
12/14/05 06:19 PM
Jim,
I never have a problem with helping ANYBODY as long as they are not attacking me personally. It takes a lot to make me mad, and when I do I get real quite, like the calm before the storm. It is a good thing I am sitting behind a keyboard because when I do lose my temper you DON'T want to be in the same room with me. After I blow up, it is over and i don't hold a grudge
Everbody is entitled to their own opinion of me. I understand that it is hard to interpet tone and feeling of people when you are reading the written word. I really hold no grudge with anyone on this board and I think many would have a changed opinion of me if the met me in person and were around me for a little while.
Re: yes, another hemi carb question ... [Re: Rhinodart] #21192
12/15/05 07:37 PM
12/15/05 07:37 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Re: yes, another hemi carb question ... #21193
12/15/05 07:37 PM
12/15/05 07:37 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
thank you darryl , that helps alot ...
Re: yes, another hemi carb question ... [Re: moparmarks] #21194
12/15/05 07:38 PM
12/15/05 07:38 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
thanks , thats a progressive linkage , but if you look closely you'll see its setup so that they pull at the same time .
Re: yes, another hemi carb question ... [Re: JohnRR] #21195
12/15/05 07:55 PM
12/15/05 07:55 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
John, a freind of mine used the setup from Necombs with his hemi using the eddys. It runs like a scaulded dog. I had no trouble tunning the carbs and getting it to run smooth from idle to full throttle, and its a 4 speed.
Re: yes, another hemi carb question ... [Re: JohnRR] #21196
12/15/05 09:23 PM
12/15/05 09:23 PM
john, moparmark has the edelbrock progressive linkage in both photos. the hemi just needs the linkage moved down to the smaller hole to be progressive(note the 2nd photo of the ch28 dual quad). that is pretty good linkage. add the edelbrock throttle adapter on the rear carb and all stock kickdown linkage can be used.
Re: yes, another hemi carb question ... [Re: JohnRR] #21197
12/15/05 10:27 PM
12/15/05 10:27 PM
moparmarks Offline
moparmarks  Offline
No. The primeries on the rear carb open before the primeries and the front carb. The little black block is off of the rear brass block.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: yes, another hemi carb question ... #21198
12/16/05 02:18 PM
12/16/05 02:18 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
i see it being progressive on the second pic , i don't have an eddie carb in my hand to compare the linkage . in the first pic on the hemi engine the linkage looks like its on the top big hole on both carbs and the black slide collar is all the way to the rear making both carbs open at the same time and speed . but it just may be an illusion because of the angle of the pic and the distance from the carb
the pic 66hemi attached shows me better what to do once i get a couple of carbs on the mainfold at home and compare it to the pic .
