Non-Matching Sway Bars, Hotchkis and Addco #2119230
07/27/16 06:49 PM
07/27/16 06:49 PM
Chicago, Illinois
Devil Offline OP
Devil  Offline OP
Chicago, Illinois
Recently, I've been able to acquire a Hotchkis E-body front sway bar 2254F. 1 1/4 in. Tubular
http://www.hotchkis.net/product/front-sp...ort-suspension/
Now I've gotten a Addco 674 E-body rear bar, 7/8", and I believe a solid bar, not tubular.
https://www.amazon.com/Addco-674-Sway-Bar-Kit/dp/B004A0ZATM
How do yo guys think of the tubular and non-tubular sway bars will react on my 71 Challenger? I haven't seen a combination like this on any of the forums. I believe that they should be fine, but I would appreciate a few other opinions.
Next up, torsion bars!
Ryan
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2119272
07/27/16 07:37 PM
07/27/16 07:37 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The front bar is good (lighter weight being hollow and the OD is the primary factor for stiffness).
The rear bar is too small at 7/8 but adjustable ends are good (make it at its shortest for better results)... also its better to be hung on the frame instead of the axle... choice of designs.. easier to install on the axle (thus easier to sell).
I use 1.25" solid front and 1.0" solid rear... each custom-made. Then, I've layed with the end links ... 1/2 rubber, 1/2 poly to satisfy my results... experience tells what a driver likes/doesn't like.
I've recently purchased a Firm Feel 1.25" hollow front bar to try out... lighter weight is the goal.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Mopar Mitch] #2120360
07/29/16 02:24 AM
07/29/16 02:24 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Well, Mitch would know the handling dynamics of the short wheelbase E body. If I used those in my longer 70 Charger, I'd have a severe oversteer condition. There is a ratio I read somewhere for determining a rear sway bar. It was something like size the rear bar between 60-75 PERCENT the size of the front. The front needs the huge bar due to the greater amount of weight the front end carries.
Also, look into the actual strength of that tubular bar. Once you get all the specifications figured out, you'll know what to expect.
OR you could just bolt it all in and feel for yourself.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2120362
07/29/16 02:28 AM
07/29/16 02:28 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
In retrospect... I think having both bars in will be better than having no bars in.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2120707
07/29/16 04:11 PM
07/29/16 04:11 PM
Chicago, Illinois
Devil Offline OP
Devil  Offline OP
Chicago, Illinois
Hmmmmm. The Hotchkis stock rear bar is 13/16", which is slightly larger.
I'll start figuring out some math here and see what's up.
And you're absolutely right, having both bars in, compared to nothing will be a big benefit.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2120739
07/29/16 05:04 PM
07/29/16 05:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not sure I agree with that, as the balance between the F/R is what is the goal, no matter how its achieved, to a large degree.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2120850
07/29/16 07:33 PM
07/29/16 07:33 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
The tires don't care about a mis-match of brands nor tubular vs solid. Styles, mounting, lever arms and so forth are factors to consider. My 1" under axle bar produces the same rate as a 3/4" frame hung bar because of mounting points and arm length.
Balance is where its at.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: TC@HP2] #2120963
07/29/16 10:36 PM
07/29/16 10:36 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
I think the point would be sprung weight vs unsprung weight as far as the best mounting of the rear bar.
Yes, the tires have no idea which bar type is used, or where it's mounted. They only 'feel' the movement of the body of the car. And so the size and shape and portion of the tire patch/tire in contact with the pavement in corners.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2121077
07/30/16 02:28 AM
07/30/16 02:28 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Math? I suggest fractions. laugh2
13/16" is smaller than 7/8".
7/8 = 14/16".
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2121991
07/31/16 04:08 PM
07/31/16 04:08 PM
Chicago, Illinois
Devil Offline OP
Devil  Offline OP
Chicago, Illinois
You're right. I didn't actually do the math and typed it before I left for the Red Barn.
So I think I'll get the Hotchkis rear bar, sell the addco.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2122095
07/31/16 06:52 PM
07/31/16 06:52 PM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
considering your setup appears to be still in boxes, i wouldn't sell any (unless 100% refundable) until you drive it in anger.
I have now 8! bars that i have collected in the last few years of racing my neon and now SRT 5 front and 4 rear bars to fiddle with.
the mentioned 'small' 3/4" rear bar will loosen my barracuda up pretty nicely... so to echo the others: 'It depends.'
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2122100
07/31/16 07:06 PM
07/31/16 07:06 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Why not go to an adjustable bar setup instead of having 4 or 5 different ones, out of curiosity ?
I know someone with cockpit adjustable bars, mine are not that fancy...but by sliding the end link attachment point (no holes used, has clamped on style link mounts) you can dial them in pretty well. (Non Mopar, but you get the idea though... I have adjustable front and rear actually)
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2122186
07/31/16 09:41 PM
07/31/16 09:41 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
I'm not sure if the following is correct. I've had very little suspension tuning experience on Mopars. If any of the following is incorrect, hopefully someone will point out the mistake.
If you have not purchased Torsion bars yet, you may be able select a slightly different size torsion bar to make your sway bars perform correctly. In other words, if you are concerned the sway bar will be to stiff, purchase torsion bars that are a size smaller. If you are concerned the sway bar will be to soft, buy torsion bars a size larger.
The torsion bar and the sway bar work together to determine how much body roll is experienced. As has already been mentioned, the balance between the front and the rear of the car is important. So, if you have stiff rear springs and a stiff rear sway bar, you will need a considerable amount of roll resistance in the front. The roll resistance in the front will be determined by the torsion bars and the sway bar.
In my limited experience with brand X cars, I've had to swap sway bars and springs several times on each car to achieve the desired outcome. So, I wouldn't sell any parts until the car is performing in a satisfactory manner for you.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: QuickDodge] #2122247
07/31/16 11:14 PM
07/31/16 11:14 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I agree, and well stated, but, one can over do the roll resistance, unless one is seeking to return to a solid front axle set-up. grin
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: OzHemi] #2122322
08/01/16 12:49 AM
08/01/16 12:49 AM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
if that was to me... the sway bars are very cheap. 2 of the rear bars are adjustable aftermarket. the rest are OEM of one model or another some were only $45/$60 new from mopar. I would swap to smaller front bar for asphalt/sealed lots and larger for concrete... sadly no option and room for front adj without getting real creative and rolling your own $$$$
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2130448
08/11/16 05:42 PM
08/11/16 05:42 PM
Chicago, Illinois
Devil Offline OP
Devil  Offline OP
Chicago, Illinois
Sorry about not responding sooner. Had a family health issue keep me away.
I'm not looking for an all out autocross machine. I just want something that handles decently, and take the abuse I'm going to put it through.
Moving forward, I think I'll probably get about a 1" torsion bar. And alot of firm feel steering parts.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Kern Dog] #2130841
08/12/16 01:49 AM
08/12/16 01:49 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
biggest rear bar i could find, adjustable, is the hellwig 7/8" http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=10105
I'd love to have ricks 1" rear bar!
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: dangina] #2133610
08/15/16 04:08 PM
08/15/16 04:08 PM
Mopar Mitch Offline
Mopar Mitch  Offline
A long time ago (late 70s) I had custom sway bars made for my Challenger by a semi-pro SCCA Trans Am racer/driver... he made me a 1.25" front, and 1.0" rear... both duplicating the stock shapes.... they work great and in harmony together. I've fine-tuned them by trying different end-link combos ... front 1/2 rubber... 1/2 poly; the rear rubber end links.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Mopar Mitch] #2133614
08/15/16 04:12 PM
08/15/16 04:12 PM
Mopar Mitch Offline
Mopar Mitch  Offline
Another matter of concern all should consider, is the front k-frame gap where the sway bar passes through it. IF its crushed up a little (such as from jacking the front of the car at the k-frame cent section, or road damage, etc), a large diameter (~1.25") front sway bar will likely have difficulty fitting through the k-frame... requiring some extensive labor to expand and open that area.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2133628
08/15/16 04:24 PM
08/15/16 04:24 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have a Hotchkis 1.5" tubular on the front and a Hellwig 7/8" E body bar on the rear of my A-body. How mix-n-match is that? Also have heims for links on the rear with modded F250 links on the front.
Mopar to the bone!!!
