1966 B-Body Steering Column? #211908
02/02/09 02:10 PM
02/02/09 02:10 PM
Albany, New York
66Plymouth440Six Offline OP
Albany, New York
How can you identify a 1966 B-Body steering column? Does anyone have any pictures and will any other years/ models interchange? (FYI: '66 Plymouth Satellite, Auto on the floor)
A steering column came with my project car but it is disassembled and didnt have a '66 steering wheel. Before restoring it, I would like to know if it is correct or if it will work.
Thanks.
Re: 1966 B-Body Steering Column? [Re: 66Plymouth440Six] #211909
02/02/09 02:50 PM
02/02/09 02:50 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Here is a shot of a column out of a
1966 Coronete 500 Floor shift auto.
The coupler is missing and the wheel itself is currently employed in my van.
Hope this helps if you need more info let me know.
Re: 1966 B-Body Steering Column? [Re: bboogieart] #211910
02/02/09 08:21 PM
02/02/09 08:21 PM
Albany, New York
Albany, New York
Thanks. Do you have a close up of wiring connector? Hard to tell if mine looks like that.
For restoration:
-What is the correct black to use? (gloss, semi-gloss)
-What color should the shaft be?
-What color should the coupler be?
-Are rebuild kits available?
Re: 1966 B-Body Steering Column? [Re: 66Plymouth440Six] #211911
02/02/09 08:37 PM
02/02/09 08:37 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
66-69 connectors should all be the same. 66 column will not have the collapseable area as 67-69's
Re: 1966 B-Body Steering Column? [Re: rrunner] #211912
02/02/09 08:39 PM
02/02/09 08:39 PM
MI.
mech440 Offline
mech440  Offline
MI.
Only pic I have is of the back of the connector from a 66 belvedere ii, hope it helps
If it doesn't have a motor.....it's not a REAL sport
Re: 1966 B-Body Steering Column? [Re: mech440] #211913
02/04/09 08:09 PM
02/04/09 08:09 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
here are the shots I promised
Re: 1966 B-Body Steering Column? [Re: bboogieart] #211914
02/04/09 08:14 PM
02/04/09 08:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
#2
the only wiring in there are the turn signals and the horn. I think there is supposed to be a ground
from the column to the dash. just a small wire with round through type contacts at both ends.
Re: 1966 B-Body Steering Column? [Re: 66Plymouth440Six] #211915
02/05/09 01:12 AM
02/05/09 01:12 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I just finished putting my column in my 66 Dart. You have the same column as mine but your wiring may be different. Have you taken it apart? One thing I did was eleminate the coupler and installed a Flamming River joint. I also replaced the lower bearing support with a bearing and sleeve from the local bearing shop. far better setup than that factory plastic piece. Do you have manual or power steering? The steering columun
Re: 1966 B-Body Steering Column? [Re: dart4forte] #211916
02/05/09 02:55 AM
02/05/09 02:55 AM
Albany, New York
Albany, New York
Power Steering
I wasnt the one who took it apart (thus the main reason for the questions).
Good suggestions. Was anything else necessary to rebuild the column?
