273 Ex Manifold on 360 Head? Will it Work? #2118437
07/26/16 08:41 PM
07/26/16 08:41 PM
crabman173 OP
crabman173 OP
Hi--will a 65 273 exhaust manifold seal and work on a std 340 / 360 head like a J head?? I know bolt pattern is same just wondered if it will cover the port and seal--Thanks!!
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2118444
07/26/16 08:43 PM
07/26/16 08:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The overlap between the outer portion of the head's exhaust port and the manifold will be very very narrow. You will need to pay close attention.
I think I had like 1/8" overlap on my 65 Cuda with the 273 manifolds. Mock it up on the stand and you will see.
Don't be the exception.
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2118561
07/26/16 10:12 PM
07/26/16 10:12 PM
what Supercuda said & I forget if you want the 273 or the regular 318/360 gaskets, the ones that are whiteish on one side and silvery with indentations on the other side I forget the brand (or make your own)
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2118570
07/26/16 10:23 PM
07/26/16 10:23 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have some 273 manifolds on a 78 360. I had to plug the smog/emission ports but they sealed up fine with the silvery gaskets in the Fel Pro gasket kit.
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2118831
07/27/16 04:46 AM
07/27/16 04:46 AM
No, I had one customer do that exact same thing using OEM 1965 273 exhaust manifolds on a 340 motor with J heads in his 1965 cuda fastback, it was a real turd through those manifolds tskMeasure the height and width and go from there scope Maybe the Hi Po 4 barrel 273 mnifolds might, might scope have enough meat in them to allow opening(porting) them up big enough to work on the later heads shruggy
Let us know what you find out and do thumbs
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: Cab_Burge] #2118840
07/27/16 05:18 AM
07/27/16 05:18 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I was thinking the same thing. Can? - Probably will physically fit with no leaks. Should? - Probably not, due to being flow restricted. I'd at least roll the port openings back with a carbide cutter to the exhaust port actual size (NOT header gasket size).
My 2 cents is that this would definitely be either a no funds to buy other manifolds situation, or a fitment issue situation - just not a good idea if you can get the 360 manifolds that will fit the body.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2118854
07/27/16 08:08 AM
07/27/16 08:08 AM
crlush Offline
crlush  Offline
I don't see why it wouldn't seal, but your giving up alot of hp, if you have the extra cash get a set of tti headers, not sure if 340 or 360 manifolds will fit but if you don't have the cash for headers you might want to look into it.
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: crlush] #2118970
07/27/16 12:23 PM
07/27/16 12:23 PM
yes, the outlets on them are 1&7/8" which is the same as (1) big block header primary tube dia. On an early A they are a good fit for a low po DD
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: Cab_Burge] #2119105
07/27/16 03:11 PM
07/27/16 03:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The low po 273 2bbl and hi po 273 4bbl used the same exact exhaust manifolds.
The only direct dyno test I seen showed all the small block manifolds within about 10 hp on a 300 HP magnum crate engine. Everything from the 273 tiny ports to the early 340 "pot o gold" manifolds. I know my old 66 dart when I started off had the factory 273 manifolds and switching to 340 manifolds did not show up in the time slip but it was a stock 360 at the time(talk about a huge let down after hearing all the hype and coughing up $500), maybe a big built stroker or something would show more difference. Even the FAST guys all seem to be in agreement that extrude honing is pointless also. I think if you are running manifolds run what you brung and don't worry about it.
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2119109
07/27/16 03:17 PM
07/27/16 03:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Here you go
http://www.hotrod.com/how-to/engine/mopp-0307-mopar-crate-engine-exhaust/#photo-18
Note the 318 manifold they used is the same as a 273 manifold
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2119111
07/27/16 03:23 PM
07/27/16 03:23 PM
crabman173 OP
crabman173 OP
I am just asking about physical--will it bolt up and seal without grinding heads etc--power robbing not the issue--Thanks again!!
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2119148
07/27/16 04:12 PM
07/27/16 04:12 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
mine sealed fine once i permanantly plugged the smog holes
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2119200
07/27/16 05:31 PM
07/27/16 05:31 PM
P
Paul_Fancsali Offline
P
My car ran hot when going threw the manifolds switched back to headers and it was fine Performance was way off also
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2119276
07/27/16 07:41 PM
07/27/16 07:41 PM
crabman173 OP
crabman173 OP
Thanks everyone!!!
Re: 273 Ex Manifold on 360 Head? Will it Work? [Re: ] #2119820
07/28/16 02:02 PM
07/28/16 02:02 PM
as said with the right gaskets/plugging the smog holes it will seal, You know us we're always going off on a tangent, we call it covering all bases!
1971 cuda tail panel emblems [Re: ] #2119841
07/28/16 02:28 PM
07/28/16 02:28 PM
California, USA
buddy69 Offline
buddy69  Offline
California, USA
Hi all, does anybody know the correct format and spacing for the 2 emblems that go on the tail panel of a cuda?
Re: 1971 cuda tail panel emblems [Re: buddy69] #2120019
07/28/16 06:31 PM
07/28/16 06:31 PM
dogdays Offline
dogdays  Offline
[]Just a slight hijack of a post, hahaha.
R.[]
Re: 1971 cuda tail panel emblems [Re: dogdays] #2120114
07/28/16 08:35 PM
07/28/16 08:35 PM
California, USA
buddy69 Offline
buddy69  Offline
California, USA
dont get on much, not too sure how to post. my apologies
Re: 1971 cuda tail panel emblems [Re: buddy69] #2120338
07/29/16 01:53 AM
07/29/16 01:53 AM
Go to the restoration forum and click on the upper left hand side under new subject and ask your question on there, hopefully someone who knows about that will respond up
Re: 1971 cuda tail panel emblems [Re: Cab_Burge] #2121346
07/30/16 03:23 PM
07/30/16 03:23 PM
California, USA
buddy69 Offline
buddy69  Offline
California, USA
Thank you
