Re: easy cyl head swap for 440
[Re: fal3]
#2118181
07/26/16 04:16 PM
07/26/16 04:16 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That's as easy of a swap as there will be. The only other parts you'll need is a set of arp head bolts.
The MP 452 head is just an Ede rpm closed chamber head with straight plugs and core plugs in the ends.
[Re: fal3]
#2118218
07/26/16 04:44 PM
07/26/16 04:44 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I want to take off the oem iron heads and replace them with alum 452 heads. I've looked @ what is available, and decided the mopar alum 452 heads are my best bet. Is it that easy? Off with the old, on with the new. I'll be using the same bolt-ons. aren't those the most expensive, least desired head choice? All of the new aftermarket heads have accommodations for "bolt ons". I'd probably go with stealth heads before mopar 452's. The only thing you'll gain is weight savings.
[Re: fal3]
#2118394
07/26/16 07:51 PM
07/26/16 07:51 PM
fast68plymouth
So. Burlington, Vt.
They are the most expensive of the "OE replacement" type heads. But if you want American made with straight plugs, those are pretty much the only choice.
Other than price, I wouldn't say they are any less desirable than a set of rpm heads(since that's what they are), and depending on which headers you have, or stock manifolds, they might be more desirable for a particular set of needs.
Personally, I'd rather have the MP 452 heads than a set of stealth heads.
[Re: stumpy]
#2118789
07/27/16 01:52 AM
07/27/16 01:52 AM
RapidRobert
when you pull the heads, measure how far in the hole you are/valve relief CC's/gasket compressed thickness (if going back together with the same type, alum might change that) & CC's of both head types (everything needed) to see what your actual SCR gain will be. I'm assuming that you're in the hole far enough that quench ain't even possible
[Re: fal3]
#2118960
07/27/16 11:59 AM
07/27/16 11:59 AM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Yes, the MP 452 Alumin Heads work great with straight plugs. The MP 452 head is just an Ede rpm closed chamber head with straight plugs and core plugs in the ends. And they take the same CNC porting as the Ede
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: fal3]
#2119133
07/27/16 03:53 PM
07/27/16 03:53 PM
fast68plymouth
So. Burlington, Vt.
All you need is the heads, head bolts, and gaskets. Thats a decent upgrade, It should run noticeably stronger with the new heads.
[Re: fal3]
#2119190
07/27/16 05:12 PM
07/27/16 05:12 PM
fast68plymouth
So. Burlington, Vt.
The only possible "issue" I see from the info you posted is, you said the 906's have been milled a lot. If you don't have an adjustable valvetrain, and are using custom length pushrods, those may not work with new, unmilled heads.
[Re: fal3]
#2243505
01/29/17 06:27 PM
01/29/17 06:27 PM
Posts: 253 Pasadena, Texas
fal3
Pasadena, Texas
Adding to this post; re-posted to give an update rather then give a summary of it. Waited too long to buy the aluminum 452 heads from Summit; original selling price was about $950 per head back in the fall; price has gone up to $1400 per head making them not a good option to purchase. Was following the Promaxx thread posted last week(?), but it was not informational enough to answer my questions. Did appreciate one Moparts member stating the heads are a quality cast and made in USA. Question 1: are they factory bolt ons? My goal is to drive the car! Not looking for speed, maximum flow, HP, or torque. Ok, now for some soul searching. All the information about heads, and types, and work needed on them, and pros and cons has made me indecisive & slightly crazy. Need some guidance Moparts! Question 2: have any of you purchased bare heads, & swapped your old valves and valve springs in the new heads?. Springs are Comp 928(?) 105/280; cam is Comp21-305-4, 268AH-10. Valves and valve springs have 11,000 miles on them I like this idea b/c of cost factor, but it opens a new can of worms. I see the potential to have the machine shop say, "well, some valves weren't able to lap to fit well", or some other such problem occurs (I'm officially beyond my skill set in this department). Now I'm chasing valves and valve springs and the car sits longer. Or, is the wiser course to buy completely assembled heads. Pull them out of the box, send to a machine shop to get checked & cc'd, and install, and drive the car. The Promaxx look like a good deal for the $$$. Closing comment-heads will not be ported. Also, any other pertinent info is appreciated!
[Re: fal3]
#2243533
01/29/17 07:09 PM
01/29/17 07:09 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
Have you considered the Indy EZ heads? Unlike Indy SR heads, they don't have raised exhaust ports and they don't require special headers. Just a thought... Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: fal3]
#2243585
01/29/17 08:47 PM
01/29/17 08:47 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
[Re: fal3]
#2243634
01/29/17 10:01 PM
01/29/17 10:01 PM
Posts: 2,867 Pattison Texas
CSK
Pattison Texas
Promaxx cast,made in America ? dont think so. so I fixed my missing X
[Re: CSK]
#2243661
01/29/17 10:36 PM
01/29/17 10:36 PM
RapidRobert
Promax are heads made or imported (not sure which) by that crook Ben Gorman in Indianapolis. The ones (iron SB) he sold me as genuine Australian EQ's were actually chinese knockoffs. Promaxx is a different company entirely.
