Re: yes, another hemi carb question ...
[Re: JohnRR]
#21180
12/14/05 04:43 PM
12/14/05 04:43 PM
need to see pics of linkage setups using Ebrock or NEW carter carbs on STOCK inline 2-4 bbl intake and how it runs for you .
thanks
I don't have any pictures of it, but when I had two new Edel. 750s on my 68 Hemi Charger the factory stock linkage worked just fine.
#21181
12/14/05 04:45 PM
12/14/05 04:45 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
thanks
how did you set it up progressivly ? adaptors readily available , or make shift ?
[Re: JohnRR]
#21182
12/14/05 04:56 PM
12/14/05 04:56 PM
thanks
When I bought the 68 hemi Charger it had been a victim of the two Mopar thieving brothers that plegued the northeastern states. They had stolen the very rare Nascar intake that was on the car at the time as well as the original intake and carbs that were in the trunk of the car. I purchased an original intake and bought new repro linkage from Hemispherical Products and it fit without modification set up as the factory progressive.
[Re: JohnRR]
#21185
12/14/05 05:47 PM
12/14/05 05:47 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Heres a 66 manifold with new Eddies. I set this up as progressive and loved the out come. Sorry don't have a closer pic.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#21186
12/14/05 05:50 PM
12/14/05 05:50 PM
moparmarks
Heres the same Eddie linkage on a 440 setup.
[Re: JohnRR]
#21187
12/14/05 06:01 PM
12/14/05 06:01 PM
I dug around in my 68 Hemi Charger file and came up with these. One of these is a scan of a photocopied pictures so the quality is not real good. In fact, the quality is not real good on any of these. When the came in from my scanner to my photo program they were HUGE and I left them that way as they are a lot easier to read. Be prepared for this when you capture the picture in your photo program.
#21188
12/14/05 06:03 PM
12/14/05 06:03 PM
#21189
12/14/05 06:04 PM
12/14/05 06:04 PM
#21190
12/14/05 06:06 PM
12/14/05 06:06 PM
[Re: Rhinodart]
#21191
12/14/05 06:19 PM
12/14/05 06:19 PM
Now boys, quit being civil with each other, that is no way to finish the year!
Jim, I never have a problem with helping ANYBODY as long as they are not attacking me personally. It takes a lot to make me mad, and when I do I get real quite, like the calm before the storm. It is a good thing I am sitting behind a keyboard because when I do lose my temper you DON'T want to be in the same room with me. After I blow up, it is over and i don't hold a grudge
Everbody is entitled to their own opinion of me. I understand that it is hard to interpet tone and feeling of people when you are reading the written word. I really hold no grudge with anyone on this board and I think many would have a changed opinion of me if the met me in person and were around me for a little while.
[Re: Rhinodart]
#21192
12/15/05 07:37 PM
12/15/05 07:37 PM
JohnRR
U.S.S.A.
[Re: moparmarks]
#21194
12/15/05 07:38 PM
12/15/05 07:38 PM
JohnRR
U.S.S.A.
thanks , thats a progressive linkage , but if you look closely you'll see its setup so that they pull at the same time .
[Re: JohnRR]
#21196
12/15/05 09:23 PM
12/15/05 09:23 PM
john, moparmark has the edelbrock progressive linkage in both photos. the hemi just needs the linkage moved down to the smaller hole to be progressive(note the 2nd photo of the ch28 dual quad). that is pretty good linkage. add the edelbrock throttle adapter on the rear carb and all stock kickdown linkage can be used.
[Re: JohnRR]
#21197
12/15/05 10:27 PM
12/15/05 10:27 PM
moparmarks
No. The primeries on the rear carb open before the primeries and the front carb. The little black block is off of the rear brass block.
