Mini starter question #211647
02/02/09 08:57 AM
02/02/09 08:57 AM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
I picked up a mini starter for my 440 and on the bottom of the starter it has tow rubber nubs on it.What are these nibs for?
Re: Mini starter question [Re: 74RR] #211648
02/02/09 09:19 AM
02/02/09 09:19 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
What application did you get it for? It has to be for a V8 0r 3.9 V6. V6's with trans axles will not work as in caravan of car v6's. Also take off the plastic connector adapter at the terminals for more clearance.
Re: Mini starter question [Re: 74RR] #211649
02/02/09 10:40 AM
02/02/09 10:40 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I think they are to let moisture drain out if any should get in.
Re: Mini starter question [Re: MoparforLife] #211650
02/02/09 10:44 AM
02/02/09 10:44 AM
scratchnfotraction Offline
rubber nubs are for wires going in from silonoid to motor
one could be a drain hole boot IIRC,but seems they were insolation for the internal wires
I would have to go look at mine on the shelf again
yes,remove the plastic adapter piece that is on it and then hook up the batt and silonoid wires
you will like lifting the 6LBS starter way more than the 32LBS old style starter for sure
Re: Mini starter question [Re: scratchnfotraction] #211651
02/02/09 11:32 AM
02/02/09 11:32 AM
74RR Offline OP
74RR  Offline OP
Thanks for the replys.
Do I need to worry about these melting because of heat from the headers?
Re: Mini starter question [Re: 74RR] #211652
02/02/09 02:47 PM
02/02/09 02:47 PM
IMO...no
I seen where a starter was draging and over heating..while not working melt them
but it melted the positive cable along with burning up the starter
I got one tube of my header a finger width from the round end of the silanoid and have had no issues with heat so far
got my mini from the jy 14$ off a 94 v-6
just route the wire away from heat and your good to go!
