1979 dodg d100 step side not LRE
#2116418
07/24/16 12:20 AM
07/24/16 12:20 AM
Posts: 122 tn
timeklr
tn
well this is how the truck has progressed so far getting close, It came stock with a see thru floor for road viewing so I replaced the trans tunnel from parts truck and new floor pans the rockers where a ok (galvanized from factory Thank you dodge}
Re: 1979 dodg d100 step side
[Re: timeklr]
#2116420
07/24/16 12:23 AM
07/24/16 12:23 AM
Posts: 122 tn
timeklr
tn
[Re: timeklr]
#2116424
07/24/16 12:27 AM
07/24/16 12:27 AM
Posts: 122 tn
timeklr
tn
d100
[Re: timeklr]
#2116426
07/24/16 12:29 AM
07/24/16 12:29 AM
Posts: 122 tn
timeklr
tn
d100 The support had some rot also fixed it best I could
[Re: timeklr]
#2116427
07/24/16 12:32 AM
07/24/16 12:32 AM
Posts: 122 tn
timeklr
tn
[Re: timeklr]
#2116428
07/24/16 12:37 AM
07/24/16 12:37 AM
Posts: 122 tn
timeklr
tn
d100- I cut the floor out of my parts trucks straight bed to use in the step side , the trucks going back to being my driver and the wood just did not hold up well to previous use.
[Re: timeklr]
#2116431
07/24/16 12:42 AM
07/24/16 12:42 AM
Posts: 122 tn
timeklr
tn
d100 the interior is done I have added an a/c dash and power windows waiting till its drive time to put seat in......its covered in a grey tweed
[Re: timeklr]
#2116440
07/24/16 01:06 AM
07/24/16 01:06 AM
Posts: 122 tn
timeklr
tn
Some ol sign guy used to stand on fenders and roof to fix signs...so a little body work was needed
[Re: timeklr]
#2116445
07/24/16 01:22 AM
07/24/16 01:22 AM
Posts: 122 tn
timeklr
tn
did the best I could to clean up garage and bag it before coating with DuPont chromabase still had a bit of dust. mostly in clear at least I didn't try to tack it off between clear coat layers, I so thought I'd do that and have to re-paint(had to on color) actually hid the tack rag from myself after wiping down final color coat, sanded and polished it nice and slick
[Re: timeklr]
#2116458
07/24/16 02:14 AM
07/24/16 02:14 AM
Posts: 122 tn
timeklr
tn
Its come a long way I think , the grille adds to it if your interested in seeing how to swap over to a 76 grille I have posted a step by step post in this forum search "76 grille swap help please" to find it the most tedious part of it is cleaning of the army green and sanding/polishing the grille itself
[Re: timeklr]
#2117926
07/26/16 08:40 AM
07/26/16 08:40 AM
Posts: 8,674 Buford, GA
I_bleed_MOPAR
Buford, GA
Some ol sign guy used to stand on fenders and roof to fix signs...so a little body work was needed I bought a '74 PW long bed back in '77 for a song (318- 4 spd.) that the guy worked for a motel chain repainting their signs. Truck had white, black, and yellow dots and drips all over it. Same color as yours. Traded it in on a new '78 PW step-side. Beautiful truck. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: 1979 dodg d100 step side not LRE
[Re: timeklr]
#2122355
08/01/16 01:49 AM
08/01/16 01:49 AM
Posts: 122 tn
timeklr
tn
Thanks for the kind words guys..couldn't think of a reason to get rid of the slant six it has been great to me , all I wanted to add was a/c.
I have been working on the bed mounting and purchased a dodge Dakota rear step bumper, really like how it does not stick out far past the bed the way my old bumper use too. It was a fairly easy mount just needed to trim and drill the brackets from the step bumper off of my fleet side parts truck a bit.
[Re: timeklr]
#2139114
08/23/16 01:44 AM
08/23/16 01:44 AM
Posts: 122 tn
timeklr
tn
Well I have the box together and laid the fenders on, still need to line them up, prior to putting them on I brushed on plasti dip to mounting surface of fender rather than using welting to protect paint. Seam sealed the bed and hope to spray in bed liner next week. also picked up a 54" 3rd brake light with turn and signals to mount between bumper and bed.
[Re: basketcase]
#2153521
09/13/16 08:13 AM
09/13/16 08:13 AM
I_bleed_MOPAR
Buford, GA
Lookin' good. Tim
