318 valve cover leak #2115974
07/23/16 04:16 AM
07/23/16 04:16 AM
Marysville, WA
77ProStreet Offline OP
Marysville, WA
The drivers side valve cover leaks. I have pulled it and replaced gaskets 3 times...and it still leaks out of the back corner. I have even tried a new valve cover to no avail. I am stumped. I've tried cork and the new composite that is a little stiffer. I even went as far as using silicone between the gasket and the head. And I know the head surface is clean.
Any ideas?
Re: 318 valve cover leak [Re: 77ProStreet] #2116116
07/23/16 01:45 PM
07/23/16 01:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You sure it's the valve cover and not the oil sending unit or intake manifold?
Re: 318 valve cover leak [Re: 77ProStreet] #2116121
07/23/16 02:03 PM
07/23/16 02:03 PM
Alberta
rustbuckett68 Offline
Alberta
Did you flatten the hole and use the spreader? Is that bolt too long, by even an eighth?
Re: 318 valve cover leak [Re: 77ProStreet] #2116173
07/23/16 03:33 PM
07/23/16 03:33 PM
md
mopars4ever Offline
mopars4ever  Offline
md
these always worked for me on OEM covers
http://www.ebay.com/itm/Mopar-small-block-Valve-Cover-Gaskets-Rubber-OEM-design-273-318-340-360-/331770099992?hash=item4d3f09f918:g:CKcAAOSwvUlWszPx&vxp=mtr
I had a v/c leak problem before too. If silicone sealer has been used in the past, check the bolt holes for excess dried silicone. I use a pic to get it out of the hole. It keep the bolt from going down enough to get the cover snug.
Re: 318 valve cover leak [Re: 77ProStreet] #2116463
07/24/16 02:42 AM
07/24/16 02:42 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Cast covers, blue moroso gaskets (there still garbage BTW) and RTV to seal both sides of the gasket was the ONLY 'fix' for mine.
Re: 318 valve cover leak [Re: 77ProStreet] #2116551
07/24/16 11:45 AM
07/24/16 11:45 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try a set of Mr Gasket ultras.If they dont seal something is bent or warped.My buddy just had a set or the high buck blues leak.Replaced them with the Ultras and no leaks.Silicone and cork dont mix.If you need to use both you have a problem.Rocky
Chrysler Firepower
Re: 318 valve cover leak [Re: therocks] #2116614
07/24/16 01:17 PM
07/24/16 01:17 PM
Alberta
440_Offroader Offline
Alberta
I have fabricated valve covers, but I had the same... leak at the back of the drivers side valve cover. I found the valve cover was a little larger and when tightened down would twist the gasket down around the outside. I made the bolt holes slightly oblong on the valve cover to pull it ahead slightly. Haven't had a leak since. If you have an extra cylinder head lying around, maybe try the valve cover and gasket on it to get a good look on how everything is sitting on the head?
Re: 318 valve cover leak [Re: 440_Offroader] #2119951
07/28/16 05:14 PM
07/28/16 05:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I don't usually recommenced the use of silly-cone.
However to verify it is the valve cover gasket, get both the mating surfaces super clean, don't even need to be completely flat.
Put a 1/4 inch bead of the silly stuff all the way around on the head.
Let it set up for a good 15 minutes.
Put the cover on and lightly tighten the bolts till the silly cone just peaks out from the edge and let it set overnight.
Once the silly stuff cures, it should not leak.
If it does, then as mentioned above, it's elsewhere.
I have mechanical Aptitude.
I can screw up anything.
