Drive shaft loop that uses stock attachment points? #2115268
07/22/16 01:06 AM
07/22/16 01:06 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone know the manufacturer(s) that make drive shaft loops that require no additional holes added to the underbody floor pan or bracing? I've seen them before, but don't know who manufactures the brace? I need one for an A-Body.
Thank you in advance for your feedback!
Re: Drive shaft loop that uses stock attachment points? [Re: vinnyd76] #2115273
07/22/16 01:26 AM
07/22/16 01:26 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
Re: Drive shaft loop that uses stock attachment points? [Re: vinnyd76] #2115304
07/22/16 02:04 AM
07/22/16 02:04 AM
BlueRacer69 Offline
BlueRacer69  Offline
There use to be a guy that sold them on E-bay a couple of yrs back. The loops bolted to the transmission cross member so you had to drill no holes. Looked like a slick outfit. I think they were even powder coated. Can't say if he still sells them there or not. Wish I would of bought one back then.
Re: Drive shaft loop that uses stock attachment points? [Re: mopars4ever] #2115330
07/22/16 04:50 AM
07/22/16 04:50 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Originally Posted By mopars4ever
Yep, Mancini.
Re: Drive shaft loop that uses stock attachment points? [Re: Big_E] #2115354
07/22/16 09:43 AM
07/22/16 09:43 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
See the hole in the top of the loop, thats for bolting it to the floor, which means drilling a hole in the floor. I guess you could leave that out, but I don't think it would be very strong that way which would defeat the propose.
Re: Drive shaft loop that uses stock attachment points? [Re: vinnyd76] #2115355
07/22/16 09:47 AM
07/22/16 09:47 AM
None
71rm23 Offline
71rm23  Offline
None
www.uscartool.com makes them, sells, and has retailers to sell also
Re: Drive shaft loop that uses stock attachment points? [Re: 71rm23] #2115406
07/22/16 11:30 AM
07/22/16 11:30 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
The photo above is the us cartools , I have one in my dart , I haven't bolted it to the floor yet ...
Re: Drive shaft loop that uses stock attachment points? [Re: 71birdJ68] #2115453
07/22/16 12:48 PM
07/22/16 12:48 PM
Chicago
PurpleBeeper Offline
Chicago
Honestly, it would be safer bolted to the floor, but maybe just 2% safer? It looks pretty solid & all you have to do is make sure the driveshaft doesn't hook onto some pothole when the front u-joint breaks. The loop doesn't have to do anything except keep the front of the driveshaft off the ground, so I think you could leave that floor pan bolt out IMO.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Drive shaft loop that uses stock attachment points? [Re: JohnRR] #2115514
07/22/16 02:30 PM
07/22/16 02:30 PM
None
71rm23 Offline
71rm23  Offline
None
I think I'm going to omit it bolting to the floor.
Re: Drive shaft loop that uses stock attachment points? [Re: 71rm23] #2115796
07/22/16 09:02 PM
07/22/16 09:02 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I put one in my Belvedere, didn't know I was supposed to bolt the loop to the floor. Probably will not bother now.
Re: Drive shaft loop that uses stock attachment points? [Re: PurpleBeeper] #2115816
07/22/16 09:22 PM
07/22/16 09:22 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Not true. The driveshaft will try to swing all over the place and beat the crap out of the floor. I personally would not use that loop without bolting it to the floor. I think that much length, unsupported on one end, would be very susceptible to bending.
Re: Drive shaft loop that uses stock attachment points? [Re: forphorty] #2115841
07/22/16 10:04 PM
07/22/16 10:04 PM
Chicago
Chicago
I have to admit you make a good point forphorty. I'm not sure about the driveshaft bending, but I'm pretty sure you're right and I'm underestimating the force of driveshaft coming loose. I have personally broken 2 front u-joints + once broke front & rear at the same time and the driveshaft shot out sideways. All of those were stupid "neutral drops" when I was 16-17 & not at the track. From a stop, it's not that bad....but if you had one let go on a 3rd-4th shift at 120mph....that might be bad.
Re: Drive shaft loop that uses stock attachment points? [Re: PurpleBeeper] #2115951
07/23/16 01:52 AM
07/23/16 01:52 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
As both ads state "100% Bolt in with NO HOLES OR WELDING!!!"
Re: Drive shaft loop that uses stock attachment points? [Re: Big_E] #2115958
07/23/16 02:36 AM
07/23/16 02:36 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I don't get it.
If your "racing" the car it is not original.
So with all the other modifications, why not drill one little hole?
If your not racing it there is no need for the loop.
shruggy
I have mechanical Aptitude.
I can screw up anything.
Re: Drive shaft loop that uses stock attachment points? [Re: Big_E] #2115970
07/23/16 03:42 AM
07/23/16 03:42 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
But yet they put the hole in the loop . . .
Can it be installed with no holes or welding? Yep.
Should it be installed without bolting the loop to the floor? IMO probably not.
I've installed 4 of them in cars and I took the time to weld a 3/8" nut to the interior side of the driveshaft tunnel on all of them - makes for easier install/removal later.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Drive shaft loop that uses stock attachment points? [Re: vinnyd76] #2117469
07/25/16 05:58 PM
07/25/16 05:58 PM
None
71rm23 Offline
71rm23  Offline
None
This is the response from Uscartool via email. Guess it's up to you if bolt it in or not. I'm just the messenger here.
"Hello ***, it can be bolted to the floor. its optional and intended for full on Race Cars when bolted to the floor, otherwise it serves the same purpose. we just offer the hole as a precaution to those who want the option or more attachment. They are NHRA approved!"
Re: Drive shaft loop that uses stock attachment points? [Re: PurpleBeeper] #2117665
07/25/16 10:15 PM
07/25/16 10:15 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
iagree
Re: Drive shaft loop that uses stock attachment points? [Re: vinnyd76] #2117669
07/25/16 10:20 PM
07/25/16 10:20 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Has anyone broke a front u-joint with one of those bolt on driveshaft loops? I'd love to hear how it performed.
